bike keeps dieing
Discussion in 'XJ Technical Chat' started by reichert35, May 26, 2009.
  1. reichert35
    reichert35 New Member
    missouri
    So im lost and dont know what else to try my bike starts fine and idles smooth but after about 5 min of riding it starts missfiring and if i let off the throtal or engage the clutch for even a second it dies and i have to pull over on the side of the road and wait about 2 min before it will start again ive already drained the tank and inspected it. The kreem tank liner is intact no peeling that i can see so i filled it back up with fresh gas, ive also changed my fuel filter and made sure my carb holders were tight with no air leaks. please help im lost, also my tach seems to be jumping around alot could these two problems be related?
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Check the vent in the fuel cap and make sure it's clear.
  3. jamings67
    jamings67 Member
    CT USA
    Check your coils they may be bad. ?
  4. reichert35
    missouri
    vent cap seems clear how can i tell if the coils are bad?
  5. jamings67
    jamings67 Member
    CT USA
    CHECK THE RESISTANCE WITH A METER LOOK FOR CRACKS AND TRY ANOTHER SET IF YOU HAVE ONE.
  6. reichert35
    missouri
    thanks ill try that and let you know what happens
  7. bill
    bill Active Member
    Raleigh, NC
    Try running with the cap open. I'm still betting vent vs coils...
  8. cole9900
    cole9900 Member
    North Texas
    Have you tried running with the petcock set on prime? If that works, you may have a slow leak in the vacuum line to the petcock, allowing the gas to gradually get cut off.
  9. reichert35
    missouri
    i have tried to run it on prime and it last alittle longer but eventually i get the same result i will try a ride with the cap cracked open later. thanks
  10. Stamplicker
    Stamplicker Member
    London Ontario
    Sounds like petcock rebuild time
