Bike out of balance?
Discussion in 'Hangout Lounge' started by tabaka45, Sep 20, 2017.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If I coast in neutral, hands off the handlebar, with my Honda Rebel or my XJ700 the bike is perfectly balanced and tracts true and straight. However, with my Honda 750 Shadow it wants to slightly pull to the right. I can lean a little to the left and keep it on course. I've checked the rear wheel alignment and it is good. It is so slight that it isn't noticeable at all with hands on the handlebar. Granted, I don't normally ride hands free but I am curious about what is causing the pull. Any ideas?
    Headstock bearings tight, and not notchy?
    Forks aligned to the wheel? Bars aligned to the forks?
    Both rear shocks adjusted the same?
  3. Polock
    there's so many variables it's hard to tell, tires, speed, same road, try moving your wallet to the other pocket. that might tilt you over a bit and fix it.
    even if the tires are in alignment, are they square to the ground, like | /. or just don't do dat
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Yep. Crown of the road... trying riding against traffic on the other side and see if she pulls left.
    Uh no, don't really do that ^^^
  5. tabaka45
    Brunswick, Georgia
    Bearings and bars are fine. Will check the fork alignment--that was my second thought after the tire alignment. I'll check the shocks but I've never touched them.
    Tried on a perfectly flat parking lot but it still pulled right. Even crossed the center line on a vacant road and I can get it to tract true due to the crown, but it never pulls left.
    I'm really thinking fork alignment. Not a big deal, but I am curious.
    Stumplifter likes this.
  6. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    THE OTHER BIKES YOU LISTED ARE IN-LINE ENGINES, RIGHT? COULD THE V-TYPE CONFIGURATION OF THE SHADOW BE A FACTOR?
  7. tabaka45
    Brunswick, Georgia
    Don't think so. My wife's 750 Aero tracts true.
  8. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Also think of cable runs. If your clutch or throttle cable is a little short or long, run incorrectly, or you've got aftermarket bars/risers that changed the arrangement, it can put a bit of steering input on the handlebars, steering the bike. If you get the front wheel off the ground, is it easier to push one the handlebars one way vs the other (as in does one way drop faster than the other)?
  9. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Have you checked that the fork oil is even and at the proper level on both fork tubes?
  10. tabaka45
    Brunswick, Georgia
    The bike is bone stock 2001 Honda Shadow. It has done this since I got it from my son with about 3300 miles. It now has about 38,000. Hadn't thought about fork oil levels but it might be worth checking. The forks have never leaked. It is so slight that I even thought it might be the windshield which I might recheck.
