bike runing problem
Discussion in 'XJ Technical Chat' started by yamahamaxim1982, May 21, 2007.
  1. yamahamaxim1982
    yamahamaxim1982 Member
    minnesota
    hi my bike wants to die om me if i dont give it gas a litle with the choke off worm or cold i synk the carbs i tryed to ajust the idele on the botom of the carbs what could it be.
  2. capy
    capy Member
    Florida
    Could be a vacuum leak, bad plugs or poor fuel mixture.
  3. capy
    capy Member
    Florida
    Could be a vacuum leak, bad plugs or poor fuel mixture. Kinda need a little more info.
  4. gitarzan
    gitarzan Member
    Columbus Ohio
    Thanks I have the same issue. Just bought an undermaintained '81 550r and it does the same thing. I've been running seafom in the gas to some avail.
    I'm going to look for a leak with the propane trick in the next evening or two.
    It already has new plugs and I hope the seafoam is working by cleaning the carbs and not just softening some rubber making it swell and stop leaking somewhat.
  5. yamahamaxim1982
    minnesota
    hi what is the old propane trick,and i cleand up my carbs and i got new plugs my mixture might be off im geting a colortune sune,thank you ivan
  6. IndyMaxim
    IndyMaxim Member
    Indianapolis
    I assume it's the same as when you spray starter fluid on your boots and see if the engine revs, if it does you have a leak.
