Bike runs but wont idle unassisted
Discussion in 'XJ Technical Chat' started by Mace gaines, Apr 11, 2022.
Tags:
  1. Mace gaines
    Mace gaines New Member
    Texas
    I got my bike running last week but now i can only ilde it by gently holding the accelerator, as soon as i let go it stops idling, it was idling unassisted at first. I tried opening the airbox and moving the filter all the way off the box, but it wont idle with that either, even when i use the choke. I thought it was running pretty dry but i got some fire out of the exhaust. Can it refuse to idle if its running too rich, or do i need to tune the carbs? Ive tried almost everything but tuning, including disconnecting the tank and using only whats in the filter but no cigar. Im lost fellas.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    well , the obvious thing you dont mention is , have you tried to adjust the "idle screw"
    you dont mention which bike , but idle screw is usually fitted between the carbs 2 and 3 underneath, you may be able to see it by shining a torch under the carbs, the end of the knob "usually" has notches on it so you can tap it round with a long flat bladed screwdriver
  3. Mace gaines
    Texas
    Thank you for the insight i have seen the knob, i should have read my manual more. I will definitely try this before i try any tuning.
  4. bensalf
    yorkshire ,england
    so , working from the R/H side of the bike, tap the notch at the bottom to screw the knob "in" , to increase idle
    tap the notch at the top to decrease the idle
