Bike stalls out in 1st
Discussion in 'XJ Technical Chat' started by Mace gaines, Apr 14, 2022.
  1. Mace gaines
    Mace gaines New Member
    Texas
    Okay. I know that i am a fountain of ignorance, but this is an ask i have to make. I fixed my idling issue, i am very happy about that, thank you gentleman.; but the new issue i am running into is that i will engage the clutch, shift down to first, and the bike lurches a bit and dies. I have tried it while holding small pressure on the throttle and it still dies. I am waiting on a clutch cable so my shifter is currently a vise grip, as im only field riding it to become familiar im not too concerned. Should i wait on my cable or is there something im doing wrong? Im a decent mechanic but new to motorcycle riding.
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Check for a sticky kick stand switch.
  3. Mace gaines
    Texas
    If that is a common issue i dont doubt it. This bike had been sitting before january when i got it and i just got it started a week ago
  4. lostboy
    Clean and lube the plunger on the switch. It's low to the ground and gets a lot crud in it.
  5. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    is the neutral light comming on, ?
    if you dont have a clutch cable on, then that is the problem.
    the bike will die when shifted into gear, if the clutch is not disengaged, there is a switch on the clutch lever
