Bike starts and runs at 6000 RPMS
Discussion in 'XJ Technical Chat' started by gman, Aug 28, 2011.
  1. gman
    gman Member
    Grand Rapids Mi
    The bike starts instantly and runs up 6000 rpms. The idle adjustment has no affect on this.
    Stripped the carb bodies down to the bare essentials. I mean we removed everything.
    Cleaned the bodies by soaking them in a bucket of carb cleaner and a scrubbed all parts clean using parts cleaner.
    Bottom line the carbs look like new. Inside on out.
    Did the bench sync per the tutorial posted here. Copied the number of turns the jets go into the carb housing to the letter
    It starts great but it would be nice if it would idle. I don't think it would be good to operate a bike at only 6K rpms :D
    I am stumped. Any suggestions?
    Jason Provenzano likes this.
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    turns INTO the housing? You measure the number of turns OUT from lightly seated all the way IN.
    Or is that what you meant?
  3. RickCoMatic
    The Linkage MUST be stuck open.
    Check the Cable Hook-up is not jammed-up.
    Make sure the Manifold Clamps aren't fouling the linkage.
  4. gman
    gman Member
    Grand Rapids Mi
    Linkage is fine, it moves freely. First thing we checked
  5. swayne76
    swayne76 New Member
    Maybe try unhooking the throttle cable then start it to see if the problem goes away. I had the same thing, I had caught the throttle cable under the tank pulling it too tight. It was causing the bike to start with the throttle open.
  6. gman
    gman Member
    Grand Rapids Mi
    It's worth a try.
  7. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Just thinking out loud here, did you ever take out or check the air jets, they are sort of reverse from fuel jets (big number for pilot air, small number for main air)
    OR maybe you've dropped a pilot jet or two somehow and your drawing WAY too much gas.
    Hopefully Rick will post that awesome pic he has of the air jet placement.
  8. gman
    gman Member
    Grand Rapids Mi
    Checked the linkage. All is fine.
    Still starts at full throttle
  9. splazoid
    splazoid Member
    WI, USA
    Perhaps the choke is stuck on?
    Otherwise I also vote a jetting issue.
  10. NigeW
    NigeW Member
    Bradford, UK
    Try backing the idle adjuster all the way off, then start the bike and see if it's made a difference. Even without a throttle cable fitted the idle adjustment screw could be holding the throttles open. Nige
  11. TIMEtoRIDE
    If it's not a trapped throttle "quadrant" or a tight throttle cable, then it's one thing . . .you have one butterfly severely out-of-kilter and it's holding the others open. You botched the bench sync somehow. :eek:
  12. bigfitz52
    How completely "removed everything?" Butterflies and throttle shafts, and installed new throttle shaft seals?
    If you "broke the rack" you might not have the carbs back completely lined up correctly and the linkage could be binding.
    What method did you use to set the float levels?
  13. gman
    gman Member
    Grand Rapids Mi
    Everything as in the carb body was devoid of hardware.
    Yes we broke the rack. As far as I can tell the linkage is working fine.
    Float level. Honestly that never crossed my mind. I guess that is next on the list.
  14. junkmn
    junkmn Member
    Colorado
    I would bet your floats are in upside down.
