Bike throttle high when shifiting 1982 XJ650 Maxim
Discussion in 'Hangout Lounge' started by Littledragon, Sep 15, 2013.
  1. Littledragon
    Littledragon New Member
    In shifting from one gear to another when the engine is warm when I close the throttle the rpm does not fall back quickly as it should. The rpm only falls a little when I close the throttle and takes several seconds to fall enough to make shifting not much fun at all. Does any one know what would cause this? I know it is probably a carb issue but any ideas would help.
  2. Polock
    sync the carbs while the engine is warm and running
  3. bigfitz52
    Not "probably."
    Get your valves in spec; clean, service and then adjust the carbs as above.
