bike trailor
Discussion in 'XJ Technical Chat' started by ant797, Aug 19, 2016.
  1. ant797
    ant797 Member
    western australia
    what do people think this cant be good for the bike in neutral going over 100kmh on a long trip can it might get one if its ok $_20.JPG
    MattiThundrrr likes this.
  2. Rod1
    Rod1 Member
    San Luis, Argentina
    the problem will be if you have a flat back tire while on the road and you don't realize it...I guess...
  3. TheCrazyGnat
    Central PA
    I've heard it said that this is a bad idea for a shaft bike, unless you remove the driveshaft so that it doesn't turn the transmission.
    k-moe and Stumplifter like this.
  4. dkavanagh
    Rochester, NY
    it bugs me that we can't go back and edit topic titles to fix typos.
  5. k-moe
    You heard correctly.
  6. TheCrazyGnat
    Central PA
    I heard it from a good source: you! Ha ha.
  7. Polock
    that looks like you should have some sort of light on the bike
    TheCrazyGnat likes this.
  8. ant797
    ant797 Member
    western australia
    turns out its custom made for harleys proberly not good for a shaft drive as said ohwell seemed like a cheap compact option
  9. k-moe
    The concept has been around for at least 20 years; they aren't just for HD.
    Cheap and compact options abound, but that is the most compact of all.
    Harbor freight makes a small folding trailer that many people have modified into bike haulers. Once folded it can be stored upright against a garage wall. They do require new bearings from the get-go though.
