Bike turned off, won't turn on electrical.
Discussion in 'XJ Technical Chat' started by joechicago, Aug 11, 2015.
  1. joechicago
    joechicago New Member
    Chicago
    I was riding to work a month ago, and the bike randomly turned off at a stop light. Turned back on. Made the final turn to work and it just turned off and wouldn't turn back on.
    Put a new battery in a month ago, rebuilt the starter. It worked great until now.
    I put a screwdriver to the solenoid and it turns the engine over but doesn't start it. It doesn't show the neutral light, or turn on any of the power. Tried bumpstarting to no avail.
    There's no power, but it's a fully charged new battery.
    Tell me XJ wizards what should I do?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Fuse box check out and replace with new blade style fuse holder. All the power goes through there and that would be a great place to start.
  3. joechicago
    Chicago
    Where is the fusebox? I have the tank off.
  4. MN-Maxims
    Saint Paul, MN
    Should be under the seat on a 650 or 750. 1100's have the fuse box under the RH side cover
  5. k-moe
    Yep. Under the seat, on top of the airbox.
    Based on your avatar you seem to have a 650 Maxim. It's helpful if you put that information in your signature along with the year of the bike.
  6. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Same thing happened with mine. Main fuze was ok, but the clips were shot. I replaced all 4 fuses with inline fuse holders.
    quebecois59 likes this.
