bike will not idle when warmed up
Discussion in 'XJ Technical Chat' started by BlackSpanker, Jul 18, 2011.
  1. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    It idles high when first started, then after a ride for 5 minutes it wont idle at all. could it be a vacuum leak? 3 of the spark plugs indicate that the carb is perfectly asjusted, the forth is fouled, it could be with gas or oil. I will readjust the carbs. thanks
  2. bigfitz52
    It could very well be a tight valve or two. That's a classic symptom.
    As has already been suggested to you in your other threads; YOU NEED TO CHECK YOUR VALVE CLEARANCES.
    PRIOR to carb tuning.
