Bike won't start
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, May 24, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    So xj750....rebuilt carbs....church of clean before you ask Haha...broke rail all new seals...getting spark... I adjusted valves.... it ran before all of this...two of the carb bowls let fuel out..other two don't? Thoughts? Two and for have fuel..1 and 3 don't....Thx in advance
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Polish the float needle seats with metal polish and Q-tip. Check your wet set float heights.
    Chances are the float needles are hung up due to friction or not opening due to improper float height.
  3. k-moe
    Did you wet-set the fuel levels?
    You may have stuck floats (common to have happen during the first fill after a rebuild). Give the float bowls a rap with a screwdriver handle to free them up.
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    What does wet set the fuel levels mean?
  5. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  6. Jetfixer
    Definitely sounds like either the float is stuck or when you put he fuel tubes back in, I'm assuming you put new seals in if you put some type of lube (Vaseline?) it could be plugging up tube? Anything is possible did you replace needle and seat some needles are longer requiring the float height to be reset.
  7. DrewUth
    DrewUth Active Member
    South Jersey
    You said in your first post that you had been to church, and then you asked "what does wet setting the floats mean?"....these things do not match up...
    rocs82650 and k-moe like this.
