blinkers
Discussion in 'XJ Technical Chat' started by jeishen, Aug 25, 2010.
  1. jeishen
    jeishen Member
    North Port, FL
    Is my 82 xj650 maxim supposed to have self canceling blinkers? If so I got beat for some cool flashers
  2. Ravenz07
    Ravenz07 Member
    I dont think they are supposed to be self canceling. My 81 doesnt, you have to push in the turn signal switch to turn them off.
  3. jeishen
    jeishen Member
    North Port, FL
    yeh thats the way mine work...
  4. 1904xj
    1904xj Member
    San Diego CA
    If you have a factory relay it should self cancel.
    Once you change the stock signals you either have to use something with the same draw as stock ones or your signal realy will not make your signals blink. In case you don't mind the self canceling being gone you can always get an electronic relay for fairly cheap at autozone. That relay will make any signal lights work but it won't self cancel.
  5. jeishen
    jeishen Member
    North Port, FL
    I guess i dont have the relay because the blinkers are original I am going to have to look into this because i think it would be a great feature to have
  6. 1904xj
    1904xj Member
    San Diego CA
    Check under your gas tank it should look like this.
    Right under the tank. hook up like this.
    Thas the electronic one I was talking about but thats where the stock one hooks up. kinda expensive new. Mine's for sale I don't need it since it won't work with my signals :( .
  7. jeishen
    jeishen Member
    North Port, FL
    how does it cancel the turn signal if it is just a relay?
  8. 1904xj
    1904xj Member
    San Diego CA
    It was a third prong that hooks up to the cancelling unit already on your bike. I have a 1981 maxim an dit has it. Do you have a wiring diagram? You can clealy see in there.
  9. jeishen
    jeishen Member
    North Port, FL
    I dont have a diagram i'll search the forum for it
  10. 1904xj
    1904xj Member
    San Diego CA
    PM sent.
    Check that link.
    If its not a link copy and paste.
  11. jeishen
    jeishen Member
    North Port, FL
    It would seem there is a switch in the speedo that needs to be engaged. the speedo i have came off a 550 because it was bad when i got it. Do you think this could be the culprit? Did the 550's not have self canceling blinkers? The reason i ask is because i could never get lights on the speedo I figured it was a blown bulb. maybe it was never compatible.
  12. 1904xj
    1904xj Member
    San Diego CA
    I don't know really...
    that diagram should show how it all works.
  13. chacal
    All XJ-series bikes have the self-cancelling feature (although on the XJ700 models, the self-canceller unit was built into a large, integrated "relay" box rather than being a stand-alone component).
    The self-canceller picks up the "distance travelled" input signal from the speedo reed switch, which is on the white wire with the green tracer stripe.
    The 550 Maxim speedo and the 650 Maxim speedo units are the same, and the plug-in connector should be the same, too. The 550 Seca is a different version.
    As the front wheel spins(or, just the speedo cable if you disconnect the speedo cable at the wheel), the reed switch opens and closes. If you set a multimeter between the white/green wire and the black wire of the self-canceller harness connector (main wiring harnesss side), the resistance between those two wires should alternate between zero and infinity as the speedo cable is rotated.
    If not, either there is a bad connection or the reed switch is bad and must be repaired (??) or replaced........
  14. Ravenz07
    Ravenz07 Member
    All do? Uh oh, I guess thats another thing I have to add on the list. Its something I will have to track down eventually.
  15. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Put it WAY out there on your list. If you haven't missed it before now...........
    Unless you need a winter project!
    Loren
  16. jeishen
    jeishen Member
    North Port, FL
    Thanks for all the help guys
  17. Orange-n-Black
    Memphis Area
    I saw the pic of the painted tank on your bike in your gallery, did you paint anything else? Come on show us some pics! :p
  18. Ravenz07
    Ravenz07 Member
    Lol there is much to be done before I worry about a luxury item! Its odd that I never knew that it had them though!
  19. jeishen
    jeishen Member
    North Port, FL
    I didnt paint the side covers yet because I dont have a right side cover lost one in the crash. But Im planning on doing the side covers and the exhaust fenders and bars. Im just working on getting the cash up
