Blowing Fuses
Discussion in 'XJ Technical Chat' started by Uyacthu, Jan 13, 2018.
  1. Uyacthu
    Uyacthu New Member
    Michigan
    I have many issues with this bike currently but for now I am simply trying to get it to fire. I am working in steps to make sure everything is covered.
    I have:
    Change plugs
    Change plug wires
    Changed the oil
    Went through the carbs
    Checked the petcock
    Changed the battery
    I am now at the point where it will almost fire but then I lose charge almost immediately. I finally broke down and went to batteries plus and purchased a sealed battery ( I had purchased a new one that was fillable just three months ago) my issue is that with the new battery as soon as I connect the battery the main fuse (30a) blows.
    When the old (still pretty new) battery is connected I do not blow any fuses.
    I am not sure if the battery they gave me is overpowering the fuses or I'm missing something.
    I have contemplated the rectifier being the issue or a short somewhere however, why would the other battery not have the same results?
    The model number of the battery is AGM 14AH-BS. The bike is a 82 xj750 seca.
    aree you connecting the correct batery wires to the battery the 750 had a different battery when it hit the production line then they made adaptors because the battery terminals swiched sides my battery is negitive on left and positive on right side with a metal extender to reach the terminal
    battery on left has + on left. battery on right has + on right side
  3. XJ550H
    you can hook a full size car battery to your bike and it will not blow fuses.
  4. hogfiddles
    Either you're hooking the battery up to the wrong terminals, or you're creating a short somewhere with a hot terminal or wire contacting the frame or some other wire/contact at some point. Or the battery itself is defective or possibly incorrectly labeled/made
  5. Uyacthu
    Uyacthu New Member
    Michigan
    It was a short. Worked through the wiring harness bit by bit and found bare copper twisted together. Compliments of the previous owner that changed out the headlight and turn signals.
    New problem however, the throttle seems to be fully engaged.
    I'm not kidding when I say this I love moving from one problem to the next. It reminds me of computer programming. Fix one problem and find three more.
    Xj550H and hogfiddles I appreciate the ideas and help.
  6. k-moe
    Let's back up.
    What do you mean by "went through the carbs"?
    Were any parts replaced?
  7. Uyacthu
    Uyacthu New Member
    Michigan
    I sho uld have mentioned I am not mechanically inclined nor have I ever owned a motorcycle before. A friend traded me this bike for some computer advice/repairs. Its quite the project but it's been interesting digging in.
  8. Uyacthu
    Uyacthu New Member
    Michigan
    There was a rebuild done on them by a mechanic last year. When i say i went through them i mean i sat with the church of clean and my haynes manual and opened up the carbs and inspected parts for grim and anything that may be holding them up. All parts that are replaceable were done so during the rebuild so it was in very good condition.
    However, one of the previous owners became a little ambitious with what i can only assume was not the proper paint and sprayed the carbs. They now look chipped and melted so i thought it may be worth the look just in case.
  9. XJ550H
    throttle fully engaged. this could be the Idle knob is turned in to far. it could also be that the barrel on the throttle cable is not sitting in the cup on the holder that is attached to the carbs or the adjuster at the throttle grip is turned out to far pulling up the linkage.
    does the throttle shaft move freely when you twist the grip?
    then there is the linkage on the carbs the throttle cable is hooked to it could be hung up on the head. look at the second and third picture in this link
    OWWW, My Eyes!
    you will see the cable linkage in the upright position in the second photo and extended out in the third photo
    paint could have eaten the throttle shaft seals
  10. XJ550H
    that is why you work through one system on the bike at a time examine each one. wiring, charging ,ignition ,fuel, and motor which would be valves, compression and oil leaks , brakes.........
  11. Uyacthu
    Uyacthu New Member
    Michigan
    Ok, ive looked at the lever. Particularly the spring. This seems to have a mixture of grease buildup and possibly an over spray of paint. This could be causing the issue?
    When I pull the throttle (motorcycle off) and release it, it moves back to closed only partially then I can watch it slowly move to a full off position (throttle grip). However, it doesnt seem that the lever on the carb is fully disengaged when this happens.
    If I were to force the throttle grip all the way open and then back closed again i can still manually move the lever (on the carb) to a more closed position.
    I am under the assumption this could be from the grease build up/ overspray paint or a faulty throttle cable?
  12. Uyacthu
    Uyacthu New Member
    Michigan
    I really appreciate this forum and the help from the comments I am forever greatful for finding this site.
  13. XJ550H
    lube the throttle cable. if you remove cable from linkage check to see if it moves freely to see if ppaint and grease is binding you up although it could be another issue with the butterfly disc not being reinstalled correctly during last rebuild
  14. k-moe
    I'd also remove the right hand controls to clean and lubricate the throttle tube (use graphite as a lubricant between the throttle tube and the handlebar).
    I'd also inspect the throttle cable for wear and frays.
  15. Uyacthu
    Uyacthu New Member
    Michigan
    Appreciate the help. I will post updates as soon as possible. Or should this be the start of a new thread? I don't frequent forums so I'm not sure of appropriate etiquette.
  16. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    That's the title of a motorcycle restorer's favorite country song.
  17. k-moe
    One thread per machine is preferred. Makes it easier to connect the dots should an issue be complicated by another issue.
    Uyacthu likes this.
  18. Uyacthu
    Uyacthu New Member
    Michigan
    Thank you.
  19. Uyacthu
    Uyacthu New Member
    Michigan
    Ok, after a long week at work I was finally able to dig into the throttle issue. Turns out one of the clamps for the carbs had pinned the throttle and I hadnt noticed. I did however open up the throttle to look at the cable. Hanging on by a thread has an actual meaning to me now. Any suggestions on a good cable and size? I would like to do the choke as well while im at it.
  20. hogfiddles
    Yes, get the right ones. Click on the xj4ever logo on the top right for our parts guy. Or email him directly at: info@xj4ever.com
  21. Uyacthu
    Uyacthu New Member
    Michigan
    Ok, thank you. I've found another challenge. The wire from the start switch has come disconnected at the plug near the headlight. Im not sure which wire it connects to since they're all either twisted copper to copper or connectors with only one end crimped.
  22. Uyacthu
    Uyacthu New Member
    Michigan
    Here's an image
  23. k-moe
    Find the same shade of blue wire. The fuse block in the background is hooked up to it instead of the other end of the wire that the fuse goes to.
    That also explains why you were blowing fuses.
    Is the whole wiring harness full of that type of crappy work!? You might want to consider getting a better replacement harness, or at least a good crimping die and the proper size crimp connectors (along with a wiring diagram).
    [Edit] someone added that fuse. What color wire is the opposite end (not pictured) hooked to?
  24. XJ550H
    start switch ? starter button , run/kill switch or main(key )switch?
    main switch has a Br(own) wire a L (blue) wire, R(ed) wire and 2 W/R (white/red)wires
    Red comes from 30 amp fuse and supplies power to switch
    Brown wire runs to fuse block to supply fuses
    blue runs to 5 amp fuse then to meter lights and computer
    white/red goes to battery sensor and computer
    run/kill engine stop switch has 2 red white wires one comes from 10 amp fuse the other goes to starter circuit cut off relay, side stand relay and TCI unit
    starter button has 2 wires a black one Ground and a L/W (blue/white) wire to solinoid
  25. Uyacthu
    Uyacthu New Member
    Michigan
    Starter switch i was trying to read the wiring diagram but its intimidating at first glance i think im making sense of it now and your comment helps tremendously. Thank you.
  26. Uyacthu
    Uyacthu New Member
    Michigan
    Most of the wires seem to be changed. There are an abundance of black wires I was assuming were ground just hand wound together but one was connect to a turn signal red. I pulled off the headlight and a lot of wires just fell out of their crimps. I'm think a new complete wire harness might be the answer. On the tail there are a lot of cut wires that had a lot of loose copper. I trimmed them back to avoid shorts.
  27. Uyacthu
    Uyacthu New Member
    Michigan
  28. hogfiddles
    By the time you get done farting around with the wires, you're STILL gonna still have a hacked-up harness. There's plenty around that are in much better condition. I'd recommend just getting another that's in better condition. You'll save a LOT of aggravation.
    Rooster53, Uyacthu and k-moe like this.
  29. k-moe
    Keep the hacked-up one to salvage wire from for projects, and for spare connectors.
    Chitwood, chacal and Uyacthu like this.
  30. Uyacthu
    Uyacthu New Member
    Michigan
    Ok, here's an update to the situation. After long searches and research I have decided to buy the Motogadget M unit blue with some switches and the Motogadget M button. I have been debating on getting the handlebar turn signals and making it simple havent convinced myself of it yet. I am also going to buy a reg/rec and simplify that situation as well as get the new starter solenoid.
    I had already purchased a new headlight and since I started I might as well as go all the way. Unfortunately for me the Motogadget devices are back ordered till sometime in February so i have some time before everything arrives.
    During my wait I have decided to write a new task list for myself. So here it is.
    Powder coat frame
    Install new master cylinder
    Build a new battery box
    Paint the tank
    Install new cables
    Reposition ignition
    I'm hoping this will keep me busy while I wait. I'm very excited to get the m unit and do away with any fear that the electrical will ever be a problem again. At least for a few years.
    If you guys have any suggestions let me know. Also if you'd like to see pictures id be happy to post some. I plan to post something for the m unit when it comes in.
  31. k-moe
    Your plan sounds good.
    FYI Powdercoat is not the be-all-end-all in frame paint. It looks good and all, but when it chips or scrapes it's a bear to make look good again.
    Enamel (single stage) is nearly as hard, and easy to repair. Just something to think about.
    There is a thread regarding wiring the M Unit that would be worth reading. Use Google to search for it. Sorry that I don't have it bookmarked (the cost of the unit would buy me another motocycle).
  32. Uyacthu
    Uyacthu New Member
    Michigan
    I really appreciate that. I have been going back and forth on powder coating for a while. I wanted to go white frame green tank (forest) but my wife said not to do the white and stay black since I will inevitably get oil, grease or dirt on it and it will be ruined.
    I am going to try and draw out a wiring diagram and see if it makes sense. I will probably post it so if there is a mistake hopefully someone or I will catch it before I make a regretable mistake.
    They are pricey but I want to do this right and make it something I can be really proud of. I shopped around on ebay and amazon for a long time and even though great things could come from the parts I decided to go in a different direction. Hopefully this investment will return on itself with satisfaction and pride. Also dont get me wrong there are a few amazon parts going on here such as grips, seat and taillights. But when it comes to the mechanical functions I really want to put the attention there.
  33. k-moe
  34. Uyacthu
    Uyacthu New Member
    Michigan
    Ok, I've been utilizing this warm weather as much as possible and I have actually gotten the bike running. Everything is performing the way that it should. Carbs are good fuel and spark is good. Now I am moving onto the wiring. Everything seems to function like it's supposed to other than things not being hooked up. I was looking at the headlight and trying to get that hooked in first. I have purchased the Daymaker headlight off of Amazon and obviously does not have the same connections as the previous headlight. I am having a little trouble figuring out what I should be connecting it into since all I seem to have is a giant nest of a mess up front. If anyone has any guidance on this that would be great. I'll post some more pictures up later when I get home of the new headlight and connectors.
  35. XJ550H
    what bike are we talking abut and did you go with stock harness?
    typicaly head lights have a common ground and a hot wire to high and a hot wire to low beam only 1 filliment lights at a time and low shuts off before high comes on and high shuts off before low comes on.
    the harness has a 3 position connector that plugs into a short connector that hooks to head light
  36. Uyacthu
    Uyacthu New Member
    Michigan
    The bike is a XJ750 Seca 1982. I think the connector maybe missing. I found a couple wires that come from the right hand switch of "Headlamp" but that is only a Blue/Black Red connector and the Blue is cut. The new headlight has a three prong connector but nothing on the bike matches. I bought an adapter with three bare wires and a female connector to match the headlight. Now I just need a place to connect them in.
  37. XJ550H
    yellow /green comes from atari computer
    green /red comes from atari computer
    and black comes from atari computer
