bodywork....
Discussion in 'XJ Modifications' started by themidnightspecial, Apr 14, 2007.
  1. themidnightspecial
    themidnightspecial Member
    Liberal, Ks
    So I have decided to go ahead and do some mods on my 83 Maxims frame. After looking at the frame I noticed that a wire feed was used to do most of the welding. Well peeps. what do i do to prevent the metal from warping, and should i use the wirefeed process or....tig?
  2. RickCoMatic
    If you can TiG ...
    Make 'em pretty.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    The idea is not to get too much heat concentrated in one area. First tack the parts together and make short welds (make sure to get good penitration) :lol:
    I usually tack everything together first, to make it rigid, then go ahead and weld. I like a wire feed in my projects because I can get a better looking weld and do less grinding and dress up afterwards. If you plan todo alot of welding, a wirefeed is a good investment.
  4. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    Mig and Tig are good.
  5. themidnightspecial
    Liberal, Ks
    Ok...Well my machine only does STICK, and TIG. So any advice on tig work?
  6. XJdude
    XJdude Member
    near the yellow dotted line
  7. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    Then I guess I will just shut up.
  8. themidnightspecial
    Liberal, Ks
    ok...well I am raising the rear end ..so I need tips. cutting...Im scared my plasma wont do the job real well.
  9. XJdude
    XJdude Member
    if u have some metal laying around, play with that first, plasma cutter is ur friend.
    if ur new to a plasma cutter, kust remember to have dry air, miostier is a plasma enemy.
    and make sure u have a good ground, other than that they are easy to use.
  10. themidnightspecial
    Liberal, Ks
    well what do you think about cutting with a Oxy-Ace cutter...I know the edges aren't as smooth....but....I dont have to use a CRAP load of power
  11. XJdude
    XJdude Member
    its up to u, what ever ur comfortable with, but if u have access to a plasma, i would use that, plasma's are awsome.
  12. themidnightspecial
    Liberal, Ks
    sweet....Well Guys....Get ready...I'll start the post here on my bike...
