Bolts for grab bar
Discussion in 'XJ Technical Chat' started by 1982 xj650, May 16, 2019.
  1. 1982 xj650
    1982 xj650 New Member
    Ontario canada
    Does anyone know the bolt size and length for a grab bar on a 1982 xj650 maxim.
    The standard cosmetic bar, or something else? There were a lot of options for the Maxim.
  3. XJ550H
  4. 1982 xj650
    Ontario canada
    K-moe, it's for the standard grab bar. The nuts are welded on the back of the brackets that are mounted to the frame.
  5. XJ550H
    is this the bolt? large one at rear of grab bar.
    it is a flange head bolt
    10mm 1.25 pitch X 25mm long around 22 ft lbs torque
    chacal likes this.
  6. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Theres also some allen head ones just in front of the shock mount stud. The shock nut also holds the grab bar on. Not sure what fastener the OP is referring to
  7. XJ550H
    I did ask him to tell us which ones
    front bolt is
    Allen head 8mm dia 30 mm long
    Chitwood likes this.
  8. 1982 xj650
    Ontario canada
    Perfect, thank you. I am out to the hardware store tonight then.
