Boring your engine
Discussion in 'XJ Modifications' started by darkangel, Mar 24, 2008.
  1. darkangel
    darkangel Member
    Liberal, Ks
    Ok....Where do I go, to get oversized pistons, crank and everything else needed to bore out my engine..?
  2. darkangel
    darkangel Member
    Liberal, Ks
    Does anyone know?
  3. capy
    capy Member
    Florida
    You might be able to get a set of piston that are oversized but you will more than likely have to have them specifically made. Most of the major upper end companys can make a custom set of pistons, Viola, for example. I do not think it would be worth the money to have them made though. Would more than likely run you more for the pistons than purchasing a good used motor.
    Might want to check in on having your head shaved if you are looking for a little bit extra. this would decrease you combustion chamber volume thus increasing your compression ratio. In essence a poor mans bore. Remember thought that this does increase combustion pressures and can cause alternative problems if other details are not paid attention to.
  4. MiCarl
    I know cheapcycleparts.com lists them available for the 650s. Stock, 1st and 3rd oversize if I recall correctly.
  5. Polock
    why would you need a crank for a bore job?
  6. chacal
