Brake Line & Air Filter recommendations?
Discussion in 'XJ Technical Chat' started by Big_P, Jan 28, 2012.
  1. Big_P
    Big_P Member
    Picked up an '81 xj650 last week, its my first bike besides mx bikes and the plan is to turn it in to a bobber. But first i want to start replacing everything.
    I pulled the airbox cover off and there was some funky air filter in there that looks like a half cylinder not attached or anything so im looking for a replacement but i have no idea what to go with. And i also want to replace the brake lines....
    So what are your recommendations for brakes or air filters? And im on some what of a budget.
    Thanks in advance for any input!
  2. bigfitz52
    The stock air filter is a "funky half cylinder" and it's held in place by judiciously placed ridges in the cover.
    Stick with stock unless you want to start a carb-tuning fight. Even a K&N can prompt re-jetting.
    Your brake lines do need replacing; it's worth the few extra $$ to upgrade to stainless. You'll also NEED to rebuild both the caliper and master cylinders; not expensive and VERY necessary.
    Visually inspect your REAR BRAKE SHOES first: http://xjbikes.com/Forums/viewtopic/t=15874.html
    Check with XJ4Ever (logo/link in site banner, upper right) for the correct parts at very reasonable prices.
  3. Big_P
    Big_P Member
    Thanks a ton that's solid advice. I guess i just wasn't expecting a air filter like that in the box its in just didn't seem right.. thanks for clearing that up.
  4. Yammadof
    Yammadof Member
    Prince Edward Island, Canuckistan
    Hi there Big P and welcome......as well as the brake stuff [front and rear] check your tires for age......also, get the rebuild kit for your calipers - everything rubber or plastic on your bike is now 30+ years old...check out the caliper from my 82 xj650RJC:
    and after:
    sending a note to chacal for brake parts....+ stainless brake lines + m/cylinder rebuild kit - going is good....stopping is better!!
    Dave
