brake line issue
Discussion in 'XJ Technical Chat' started by mrdawson, Apr 27, 2016.
  1. mrdawson
    mrdawson Active Member
    Wisconsin
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you ordered a brake line for your specific bike then you should not have to twist it much as all. When I got mine I thought the one from the M/C to the junction box was wrong, but after a number of tries I finally found the proper position for it and it fit well.
    If you have a generic line then you'll have to try the twist.
    Stumplifter likes this.
  3. mrdawson
    Wisconsin
    Lines came from Len. They are not the issue, they're beautiful. Why they wont fit correctly, after looking at enough seca's and the service manual, is that the yamaha master cylinder that came on my bike from previous owner is not the original seca MC.... so rather than having the outlet port from the MC facing forward, it faces horizontal, causing this fitment issue. As my MC is shot, can't identify it, and circlip horrendously stuck, I got an aftermarket MC. But it has the same port orientation as the one it's going to be replacing.... ugh.
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Some lessons are learned hard.
    But at least you figured it out! :D
    Now you are faced with the 'next step'.
  5. mrdawson
    Wisconsin
    yes... either get diff master cylinder, versus twisting that fitting... suggestions?
  6. XJ550H
  7. mrdawson
    Wisconsin
  8. mlew
    mlew Well-Known Member
    Apex, NC
    It is common to have to twist the banjo fillings on new lines. The people who make them know the proper length and fitting needed for the line but not the orientation. they leave that up to you. They tell you in the instructions you can turn the banjo fitting and also how to do it.
    I have installed a good number of brake lines and most of them required turning the banjo.
    Remember you can do it on new stainless braided lines but not on OEM rubber lines.
  9. mrdawson
    Wisconsin
    the procedure in those links seem reasonable to you then? Also the lines came from len and are made specific to these bikes, so had I had the proper MC... it would have been perfect.
  10. tabaka45
    Brunswick, Georgia
  11. XJ550H
    no - Kmoe thinks it is an xs 650. a lot of wires on the bottom. I will remove it today to get a better photo and see if the wiring has a id tag.
  12. XJ550H
  13. mrdawson
    Wisconsin
  14. mrdawson
    Wisconsin
    yes
  15. mrdawson
    Wisconsin
    Cool, I may be interested if we can ID it and parts available to rebuild... and I guess would need to be sure piston bore is correct size
  16. XJ550H
  17. mlew
    Apex, NC
    Yes they do. The first one even came with a special tool to help. It does not take much effort to turn the fittings.
    Even if the lines were made specific to a bike they might need tweaking.
    DrewUth likes this.
  18. XJ550H
    ask chacal if he suggests that procedure he sold you the product He would be the one to ask about the product.
  19. mrdawson
    Wisconsin
    messaged him now, ha
  20. k-moe
    Not when you buy the lines from a man who knows how to make them for your bike. Some fittings are meant to be re-clocked, others are not.
    mrdawson likes this.
  21. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    When I got my lines , for some reason the packages were marked wrong. After talking to Len and sending pictures we determined the left and right sides needed to be flip flopped. Once I did that they fit perfect. Maybe you have them reversed like mine were. Careful note make sure the marked ends are in the right place also.
  22. mrdawson
    Wisconsin
    Did examine this possibility before posting. Again, the real issue is the orientation of the MC outlet port... The yamaha one that came with bike from PO is not the original and port faces horizontal rather than forward... so forced to twist the line to attempt fit... In contact with Len now regarding twisting the banjo to allow fit.
  23. tabaka45
    Brunswick, Georgia
  24. mrdawson
    Wisconsin
  25. mlew
    Apex, NC
    I have installed dozens of aftermarket brake line sets on just as many different bikes . All those are from well known and respected manufacturers. Yes sometimes the fittings need to be turned. Sometimes they get lucky and get them right but not every time. That's why they give you a special tool and instructions on how to properly twist them.
    Yes some are meant to be turned and some are not. The lines the poster is using are meant to be turned if needed. This is a normal part of installing stainless brake lines. Just because your man got lucky on your set does not mean he did on all the others.
  26. mrdawson
    Wisconsin
    Ok cool, appreciate the input. Thanks.
    Call me extra cautious in waiting on additional input from Len.
    also... these lines did not come with tool or instructions on rotating the fittings.
  27. mlew
    Apex, NC
    Not all will come with a tool or instructions. If you ask the manufacturer they will tell you can turn them , just be careful. Its always good to be cautious if you are not sure.
  28. mrdawson
    Wisconsin
    after discussing with Len, he definitely advised against this which I can understand. The lines he provides are very specifically made for our bikes. Now I know other companies do this etc etc... But looking at the crimping on other ss lines versus the ones we get from Len, they are different. The lines from Len have a crimp and fitting just like the rubber lines, as opposed to galfers, speiglers etc which have a different crimp that appears conducive to rotating if needed. He said you have be able to rotate them very slightly but would likely result in damage.
    -in the end... going to just get a MC with proper forward facing port. prob solved.
