Brake lines
Discussion in 'XJ Technical Chat' started by Kingston, Apr 9, 2012.
  1. Kingston
    Kingston New Member
    Kingston, Ontario
    Where is the best place to buy brake lines?
  2. skoster
    skoster Member
    Edgewater, Maryland
    Top right corner of your screen:
    XJ4Ever
    Len has what you need.
  3. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    +1
    DOT approved, perfect fit, great price
  4. bigfitz52
    Important note: The assemblies Len offers are DoT approved; not just the components thereof. This is the critical distinction between buying a length of hose and a handful of couplings (all DoT approved parts) and having at it yourself. I'm a very experienced mechanic and have worked on all sorts of vehicles besides just motorcycles; and I still wouldn't trust my life to my abilities to "build" my own motorcycle brake lines.
    Plus, Len can source custom stuff nearly as quickly as stock off the shelf.
    +2. Highly recommended.
  5. sgio
    sgio Member
    Horseheads, NY
    I put stainless steel brake lines on my bike last winter and the improvement was incredible. Really scary how much those original lines were expanding. Now the brake lever is very firm.
    I got mine from XJ4ever. Highly receommended!
  6. zap2504
    zap2504 Member
    Middletown, PA
    I am assuming that the rubber brake hoses that Len/Chacal sells still need to be replaced every 4 years (per factory manual - as well as the caliper seals every other year). What about the stainless steel versions?
  7. zap2504
    zap2504 Member
    Middletown, PA
    Just curious as to whether this requirement was a XJ-specific thing or not so I checked some of my other bikes' manuals:
    KZ440 - replace MC/caliper seals every 2 years; replace brake hoses every 4 years
    XT600E - replace caliper seals every 2 years (no periodic replacement of MC seals mentioned); replace hoses every 4 years
    I'm guessing this replacement schedule pertains to most (if not all) cycles (really increases maintenance costs - especially to those of us with MBD (multiple bike disorder)) and expands costs greatly for multiple-pot calipers and rear disk brakes.
    I think this needs to be a sticky and re-named something like "Brake Line and Seal Replacement Schedule"
  8. losifer
    losifer Member
    Minneapolis, MN
    this is a good question. i recently bought stainless steel braided lines from Chacal, in part because of the added stopping power, but primarily because i assumed that the maintenance schedule was longer.
    but i just went back and re-read the description, and there is no mention of an altered replacement schedule on the steel braided lines.
    are they still intended to be replaced every four years?
  9. trickedout420
    trickedout420 Member
    Greenwood MO
    i made my own stainless steel brake line at work...cost was about 20 bucks for fittings and materials. for that price ill just replace it every 2 years
  10. zap2504
    zap2504 Member
    Middletown, PA
    Every 4 years for the brake hoses (plus all the copper banjo joint washers); it's every 2 years for the MC/caliper seals. Plus Chacal recommends replacing the banjo bolts and bleeder nipples too.
    For the 750 Seca owners, that's at least 4 hoses (plus a 5th if you switched from the cable-actuated MC to a handlebar-mount version). $175.80 in stainless steel hoses alone (from Chacal).
  11. zap2504
    zap2504 Member
    Middletown, PA
    From the Spiegler USA site:
    "A generally unrecognized manufacturer's recommendation is that all original rubber hydraulic hoses should be changed every four years to avoid failure. Spiegler brake lines are maintenance free and will provide reliable service for the life of your motorcycle."
    Len - do your stainless steel lines have the same lifetime?
  12. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    I'm no expert in this (and chacal should weigh in) but this is how I understand it:
    The key difference between rubber and stainless steel brake lines is that the rubber in the rubber hoses performs both a structural (has to contain thousands of psi of pressure) and a fluid barrier roles. As the rubber ages, it's structural properties weaken. It still retains fluid just fine.
    Stainless steel lines have rubber in them as a fluid barrier, while the stainless steel braid provides the necessary structural support. As long as the braid is unharmed, I think the lines would not need replacing (and you can visually see when steel fails, i.e. tears/rust). It should last the life if your bike.
  13. Buffalony
    Buffalony Member
    Corning NY
    I'm pretty sure the ones chacal has are teflon lined. Good product and service btw.
  14. lytew8
    lytew8 New Member
    Ottawa
    You guys are funny when you mention the life of the bike.
    We are talking of 30+ year old bikes. What the hell is the lifetime of these bikes? another 30 years? aha!
    Just a fun observation.
    The stainless lines are worth the money. Cheap and effective. Rubber has no real place on bikes anymore - in my opinion.
  15. losifer
    losifer Member
    Minneapolis, MN
    i just ordered a set of stainless steel tires from Chacal. those rubber tires are so 3 decades ago!
  16. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Lytew8, the lifespan of these bikes can be estimated by the number of owners willing to buy the parts to maintain them in a condition that keeps them on the road. And if Chacal has anything to do about it, we'll see XJ's riding around for centuries.
  17. mtnbikecrazy55
    I too would think that ss lines would have a longer maintainence schedule, but i cant say that with any real proof, just an idealistic approach of my mind.
