Brake master cylinder snap ring removal. XJ650 Seca, 1982
Discussion in 'XJ Technical Chat' started by jamcam1999, Jun 9, 2011.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    I am overhauling a 1982 xj650 Seca brake master cylinder. Having difficulty removing the retaining ring which holds the piston in. I have several sets of retaining ring pliers but can't get any of them down into the cramped space that the ring sits in. What tool should I use? Thanks in advanced
  2. RickCoMatic
    Grab an old pair of Needle Nosed Pliers.
    Cup of cold water.
    Step over to the Grinder.
    Take-off a good deal of material.
    When you've made them "Skinny", ... Grind the Jaws down-some too.
    After you finish Grinding them, ...
    Hold them in a Vice and 400-Shoe-shine the surfaces down nice.
    Then, finish them puppies with a lick of 800.
    When you are done, ... you got a Tool that's Dedicated for the job.
