Brake pads and shoes
Discussion in 'XJ Modifications' started by Gohnmad, Aug 29, 2016.
  1. Gohnmad
    Gohnmad New Member
    St. Louis MO
    I just picked this bike up in July. It has been sitting for almost 2 years. The brakes sqwheel when I first start riding. Planning to rebuild brakes over the winter. Any suggestions on material composition?
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Start a conversation with chacal. He'll set you up.
  3. k-moe
    However.....
    Rebuild the damned brakes NOW. They are the most important system on a motorcycle, and a rebuild is far cheaper than even a short ambulance ride.
    Stumplifter likes this.
  4. hogfiddles
    Or a long hearse ride.......
  5. Toomanybikes
    Tsawwassen bc
    Those piggyback shocks should be reservoir at the top if they will fit that way
  6. Gohnmad
    Gohnmad New Member
    St. Louis MO
    Thanks, I have replaced those shocks just this past weekend due to leaking. Those shocks seemed bad when I got the bike.
  7. Kickaha
    New Zealand
    They look like Marzocchi in which case they were normally fitted reservoir at the bottom
  8. Gohnmad
    Gohnmad New Member
    St. Louis MO
    You ate correct. They were leaking alot so I replaced with a oem style.
