Brake rotor compatibility
Discussion in 'XJ Technical Chat' started by D-R0CK, May 21, 2013.
  1. D-R0CK
    D-R0CK Member
    SW Washington
    So I'm looking at some rotors on eBay because mine is warped too much to be safe, and I'm wondering, what fits a '81 seca 750? Would an '83 maxim 750 disc from the same side? What else might? And trust me, I've already perused the forums for quite a while. Good weather is passing me by every day! Thanks in advance!
  2. bigfitz52
    What do you mean, "from the same side?" You're replacing them as a pair, right?
  3. D-R0CK
    D-R0CK Member
    SW Washington
    the right side was warped and just warped. wear was not excessive on either. I'll be replacing both pads (done) but just the warped rotor.
  4. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    You have to replace BOTH. They will not be the same thickness if you don't and will have major problems.
  5. D-R0CK
    D-R0CK Member
    SW Washington
    alright. still, what fits?
  6. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I believe that Seca and Maxim rotors are not interchangeable. There is a dimension called offset; it's the distance between the rotor surface and the mounting flange where the disk bolts to the wheel. I'm not sure, but I think Seca and Maxim rotors have different offsets.
  7. D-R0CK
    D-R0CK Member
    SW Washington
    thanks, that's what i was after.
  8. greg_in_london
    greg_in_london Member
    London
    An interesting comment - why do you think that discs of differing thicknesses would cause a problem ? Hydraulic brakes are self adjusting and should have no difficulty coping.
