Brake trouble
Discussion in 'XJ Technical Chat' started by kencart, Dec 3, 2014.
  1. kencart
    kencart New Member
    san francisco
    Hello,
    Having some trouble with my front brake. I just rebuilt the caliper and mc and the brakes are still soft. I'm planning on vacuum bleeding them which hopefully should fix it but I noticed fluid pushing through the reservoir gasket when I squeeze the lever. I realize I should replace the gasket and clean the fitting but I'm concerned about the pressure that's building to push it through. There's no reason there should be pressure in the reservior is there?
    Thanks!
    Ken
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    no, shouldn't get any pressure in the reservoir part.
    did you over fill it,
    when you rebuilt the master cylinder, did you replace the seals? and did you put them on the correct way round?
    did you clean out the tiny holes in the bottom of the cylinder?
    stu
  3. kencart
    kencart New Member
    san francisco
    Yes, I replaced the deals correctly and cleaned the relief hole. The fluid level is a little high, but would that cause pressure? Either way, I'm hoping to get to work on it tonight so I'll bleed it, get it sealed, and adjust the level and see if that solves it.
    Thanks!
    Ken
  4. kencart
    kencart New Member
    san francisco
    Actually, I was wondering if the relief hole could be worn and allowing too much fluid back too quickly. I don't really understand exactly how that bit works.
    Ken
  5. bensalf
    yorkshire ,england
    the relief hole is just that!
    it allows fluid to return back to the reservoir, AFTER the brake lever has been released, and the caliper pistons push back in,
    if the relief hole was worn, it still shouldn't pressurise the reservoir,
    I'm inclined to think its just overfilled.
    stu
  6. Polock
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Compressed air doesn't move like compressed brake fluid. You must remove as much air from the line and caliper as possible. I use the over night gravity pull method to get fluid through the line. Then i re-connect the line and bleed the caliper. After 100 miles or so inspect everything and bleed again. Hope this helps.
    Gary H.
  8. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I just rebuilt my calipers, master cylinder and replaced the brake lines. I took a large syringe--like you can get at Tractor Supply or a farm feed and seed--attached a 1/4 inch tube to the tip, pumped fluid in through the bleeder valve until fluid reached the master cylinder, did the same thing to the other caliper and then bled the brakes in the normal manner. I was finished in less than 30 minutes. On a rebuild I think reverse bleeding is the best and quickest method. Or--perhaps I was just lucky.
    rocs82650 likes this.
  9. BrosefStalin
    BrosefStalin Member
    Pittsburgh, PA
    I don't have anything to offer but wow, that reverse method is great.
    Good luck!
  10. bensalf
    yorkshire ,england
    this sounds a good way to bleed air out, but is there a danger of introducing more air when the syringe is filled?
    stu
  11. tabaka45
    Brunswick, Georgia
    "this sounds a good way to bleed air out, but is there a danger of introducing more air when the syringe is filled?"
    With a 60 ml syringe I didn't have to refill during the bleeding of the caliper, and I refilled after completing the first one. That said, it is almost impossible to hook up the tube without getting some air in it. But simply holding the syringe above the caliper allowed the air bubble to float up the tubing into the syringe.
  12. bensalf
    yorkshire ,england
    ah! I see, that's a big syringe!!:eek:
    stu
  13. tabaka45
    Brunswick, Georgia
    Yep, it's not for the flu shot, thank heavens! I got mine on ebay, but I think they can be found at places like Tractor Supply or farm feed and seed stores. The one I used was not made for needles, but for squirting medication in the mouth of animal. 1/4 tubing fits nicely on the tip. It is referred to as a catheter tip--ouch! Here's what mine looks like. I only bought one or two so it was about 2-3 dollars.
    http://www.exmed.net/p-1817-covidie...jf29EpmSSKJuHOdsnoGAmwABRjkurTQdwLBoCefTw_wcB
