Breather tube leaking fuel
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Nov 6, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    So its keakimg fuel out of the tune and into my oil...I took off carbs and checked floats...all seemed great...and cleaned out needle holes....any other ideas? maybe it got unstuck when removing carbs? any other thoughts? btw xj750 seca
  2. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I also went to church on carbs....problem just popped up after no issues
  3. k-moe
    Did you install an inline fuel filter to kep crud out of your freshly cleaned carbs?
    Did you replace the float needles and seats?
    Did you wet-set the floats?
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Yes i did all of that....
  5. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Transmission had an issue...bought a parts bike...engine wss running....all i did was put my rebuilt carbs on it
  6. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Wanted to sync...but it was blowing out gas thru breather tube
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Seeing how the Packers are playing right now working on your bike is a better option . . . .
    What level did you wet set your carb bowls at?
  8. k-moe
    Check the vacuum line on the fuel tank. If there is a pinhole in the vacuum diaphram on the petcock it will allow the tank to drain into the crankcase via the vacuum line.
