Broken float pin post - Hitachi Carb
Discussion in 'XJ Technical Chat' started by jamcam1999, Jan 25, 2011.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    I have a Hitachi carb with a broken float pin post. I have Devcon epoxy steel in my shop which should work ok to "glue" it back together and I am wondering if anyone has ever used this stuff to make a similar repair. It is stronger than JB weld but your opinion would be appreciated. Thanks, Jack
  2. iwingameover
    iwingameover Active Member
    Is it fuel resistant?
  3. TIMEtoRIDE
    JB-Weld is the known cure - - all surfaces perfectly cleaned.
    There is relatively little stress there.
  4. cutlass79500
    lawrenceville georgia
    I have fixed a bunch with jb weld a lot of people say it doesn't hold up to gas I have also fixed a lot of gas tank leaks with it . I believe if its mixed right and the surface is dry and clean it works fine. Had a petcock that leaked on my old kz that i sold to a friend. Its still on there been over 23 years now.
  5. RickCoMatic
    Go to Ebay.
    Buy a Set of "Parts Carbs" for short money.
    Swap the Bodies.
    Keep the stuff that you'll get with the parts carbs.
  6. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Not sure how good JB-Weld is with ethanol, that’s some nasty stuff.
  7. RickCoMatic
    I don't subscribe to to the idea of using anything short of actually welding the broken post on permanently.
    The best option is a used Carb Body swapped-out with the broken one.
    There is a Company that specializes in repairing Broken Float Hinge Pillars.
    They use a Laser Welding technique.
    Check-out their Web Site:
    http://www.motorcyclecarbs.com/_P16629.cfm
  8. PGDBUD
    PGDBUD Member
    34.116992/-117.403765
    Used JB Weld for the exact issue, it's been holding fine for 3 years now.
    Surface needs to be dry and clean, I let mine sit for 3 days before installing.
  9. Thrasher
    Thrasher Member
    I wouldn’t use motorcyclecarbs.com they gave me bad service. Does not return phone calls or emails. They sent the wrong repair kit and would not exchange it. Bad news I am out $79.00
  10. Zookie400
    Zookie400 Active Member
    Connecticut
    +1 for JB weld or similar type fuel resistant epoxy
  11. bigfitz52
    I took a look on the Devcon website; and wow. You might be fine with what you have, which Devcon product is it exactly?
