***Brute Bobb Build***
Discussion in 'XJ Modifications' started by Alysiak00, Aug 26, 2011.
  1. Alysiak00
    Alysiak00 Member
    Hello all. The start of the Brute Bobb begin!!! I'll keep it simple, the bike started as a 1982 maxim 550 that i found on craigslist and got for $400. So, needless to say here starts the beginning of a beautiful friendship!
  2. Alysiak00
    Alysiak00 Member
    Re: **Brute Bobb Build***
    removed front fender and sanded down today.
    added some rust reformer for precautionary measures to the underside
  3. Alysiak00
    Alysiak00 Member
    got headlight out and ready to sand, also got some of misc pieces off front end and labeled wires for later
  4. Alysiak00
    Alysiak00 Member
    off comes the seat and rear section....
  5. Alysiak00
    Alysiak00 Member
    rear fender and light came off and had a little surprise.
  6. Alysiak00
    Alysiak00 Member
    more rear end came off...
  7. Alysiak00
    Alysiak00 Member
    an excuse to use a power tool is a good enough one for me! out came rear subframe and grinded top frame rails
  8. Alysiak00
    Alysiak00 Member
    exhausts came off before bike was put away for the night. had a nice growing bin of parts
  9. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Good start.
    Can't believe got such a shiny bike for $400 then decided to cut it up. Grats and good luck :)
  10. Alysiak00
    Alysiak00 Member
    shes shiny enough but definitely shows her age in certain spots. For instance the rear of swingarm has slight rust spots so im stripping her down and sending her out for media blasting and primer
  11. bigfitz52
    I would recommend getting it running properly before you sink a whole bunch of time and effort into major cosmetic mods only to discover an issue with the motor.
    Have you checked/adjusted the valves, verified the float levels, and sync'ed the carbs? Run a compression test? How about at least pulled the rear wheel and checked the rear brake shoes for delamination? Checked the date codes on the front brake lines and tires?
    You might be putting the cart before the horse here...
  12. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Sweet project! I picked up an 83 xj750 about a month ago, I'll be doing the same thing to it this winter. It's fast and super fun to ride, that's for sure. Keep us updated on yours! :)
  13. Alysiak00
    Alysiak00 Member
    when i purchased the bike i drove it home believe it or not. it has a finicky starting problem which i believe is the typical rubber boot problem because they're cracked and original. Also the battery had almost no water in it which i will be replacing battery this coming spring. It doesn't want to start when its cold but if i drop start it by pushing it and dumping clutch she fires (battery i believe). She runs great but could use a little tuning. Any tips or leads on doing valve clearance, syncing carbs and cleaning? It would be greatly appreciated.
  14. retread83
    retread83 Member
    Homossasa, FL
    Fitz,I give you a lot of credit for your patience,you do keep trying!
  15. Alysiak00
    Alysiak00 Member
    sanded the stock plate mount (just in case) as well as the rear fender top and bottom.
  16. Alysiak00
    Alysiak00 Member
    headlight dome is sanded and etch primered ( forgot picture of primer lol)
  17. Alysiak00
    Alysiak00 Member
    Today started out smooth until i painted the front fender and it fell off the stand....ugh
  18. Alysiak00
    Alysiak00 Member
    got out the old siphon tube and drained the gas tank. That takes forever to get the last little bit out lol
    if you remove the petcock its a bit easier but still theres always that tiny little bit fighting you. :)
    my empty tank....FINALLY
  19. Alysiak00
    Alysiak00 Member
    taped off gas cap and applied airplane stripper to tank. Let me tell you this stuff is nasty!!! gloves is a must and i wish i would have had sleeves. The overspray burns like the devil. Anyways....I applied the stripper and then it like "melted" off. I actually forgot about the stripper on the tank and it worked to my advantage. It turned the paint into like dry potato chips and the wire wheel took it right off!
  20. Alysiak00
    Alysiak00 Member
