Cables for Ape Hangers?
Discussion in 'XJ Technical Chat' started by robehend1, Jul 15, 2013.
  1. robehend1
    robehend1 New Member
    Fargo ND
    Looking to add some 14 inch Apes to my bike. I know I'll need longer cables, my question is where the heck can I get them?
    I checked Amazon and the like, and all I find are OEM cables and kits like this: Amazon LInk
    I'm hoping thats not the only solution, since its 170 bucks just for cables. But if thats the case, thats the case.
    Any suggestions? With these and a rear fender, I'll be done with my tinkering, and can get back to enjoying the ride.
    82 Maxim 650
  2. jherka
    jherka Member
    Emmons, MN
    1st idea would be search the user Chacal and ask him if he can get them he can get anything for your XJ!
  3. jherka
    jherka Member
    Emmons, MN
    or you can use my idea i was gonna pull mine off measure it and add the length of the bars so add 14 inches onto stock length in the search on ebay its what my brother did on his and it works awesome
  4. bigfitz52
    An important note in regard to cables, shorter or longer:
    It's NOT JUST the length.
    It's the "sheath-to-cable" ratio that matters the most; how much inner "free" cable is showing past the sheath. If that's not the same (or very close) clutches and throttles won't work right and won't have the adjustment range to compensate.
    Be sure, if ordering custom cables, that you specify both inner cable length and sheath length. If the cable vendor doesn't care about these dimensions, it's a good possibility that your new cables won't fit or function correctly.
  5. robehend1
    Fargo ND
    What about the end weight dimensions? Our local northern tool has 60" cables availble for mini bikes, but the end "dongle" or whatever you call it is at least a quarter inch across, while the XJ's are much less . Do we have a measurement for those, or should I just grab a tape and measure? I don't know if they have a special name or something like that.
  6. bigfitz52
    That too.
    Mini bike parts=generally not motorcycle-duty. Northern Tool is not a motorcycle store.
    Better to contact Motion Pro or another motorcycle-specific vendor. MiniBike parts are like bicycle parts; they're simply not made for the rigors of true "motor vehicle" service.
    There are any number of places that do "chopper" cables; some are uber-expensive; but that's because they're just marking up somebody else's work. Some are quite reasonable, comparable with stock OEM cables.
    Check with XJ4Ever (PM member chacal.)
  7. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    This may sound like a dis, but I'm actually curious: why would you put ape hanger on any standard bike, let alone an XJ? IMHO, ape hangers are the stupidest looking things around, and even look worse when not on a fat ass cruiser. Plus they'll throw off the center of gravity on the bike, making it more difficult to control. I'm sure I could get used to the balance, but no way could I get used to looking like THAT? ^_^
  8. sektorgaz
    sektorgaz Member
    Western MA, United States
    I guess people have different sense of style :) Different strokes and all that ... I do agree that ape hangers generally look pretty ridiculous 8O
  9. bigfitz52
    In my house we refer to them as "armpit dryers." It seems the only logical explanation.
