Cafe project...XJ650RJ
Discussion in 'XJ Modifications' started by desmotom, Jul 28, 2016.
  1. desmotom
    desmotom Active Member
    Canada MB
    I have had my bike for over 15 years now, rebuilt it frame up 10 years ago. I haven't started it in 5 years, life got busy and insurance is stupid expensive where I live. I am in the process of going thru the bike before I start my project to be sure everything is working optimal. Pulled carbs so far, and compression check. 125-130 on all 4 cylinders, so I am sure it wont need any internal engine work. Have to check valve clearances yet.
    Plan is to change to café style seat, clip ons, rear sets and a modified fender for now. I want to make changes that can be reversed if one day I want to go back to stock. I started making a new upper triple clamp already and going to start on clip ons and rears sets.
    will try and document all the steps and keep this thread going. maybe a you tube series???
    any input on project would be awesome.
    thanks
    Jetfixer likes this.
  2. Jetfixer
    I like it how it is!! Please don't turn it into a bobber , I hate seeing a frame cut up. Like adding a fairing over rear with a modified seat pan ,but keep the bars love the café look.
  3. desmotom
    Canada MB
    I won't be cutting the frame. No changes I will be making will be permanent...
    You have a seriously rare XJ (in the U.S.). Thank you for not doing anything that can't be undone (like cutting the frame).
    desmotom likes this.
  5. desmotom
    Canada MB
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg Worked on the bike tonight. Got it started but it wouldn't idle. Would only run on enrichment circuit. Went through carbs and everything seemed good.
    Plugs.....
    Feels good to be working on it again!
  6. k-moe
    Soot, oil, oil/soot, soot. All rich and two possible valve stem seal leak/ ring leak.
  7. desmotom
    Canada MB
    Also need new orings and washers for idle screws. Missing washers and orings looks swelled
  8. desmotom
    Canada MB
    image.jpeg Well... Brought her back to life today! Idles decent( had floats upside down ).
    Have a little more tuning to go.
  9. desmotom
    Canada MB
    image.jpeg Mocking up rear sets tonight..
    Toomanybikes likes this.
  10. Toomanybikes
    Tsawwassen bc
    Perfect way to do it with cardboard first
  11. Toomanybikes
    Tsawwassen bc
    Have seen upside down floats in Hitachi carbs before.. I think they are the only carb that floats fit in both ways. Terrible design
  12. desmotom
    Canada MB
    they look like they should be upside down by the way they are shaped....
  13. desmotom
    Canada MB
    image.jpeg image.jpeg image.jpeg No more cartridge filters for this guy!
  14. dirtmax
    dirtmax Member
    BC, Canada
    That's pretty cool!
    Is it working? What kind of filter is that?
    I need to release my 4 in 1 exhaust to swap filters.
  15. k-moe
    Chacal offers several filters with the adapter. I've had mine for over four years now and have been very pleased.
    dirtmax likes this.
  16. desmotom
    Canada MB
    Made everything today, couldn't stand the mess with the cartridge filter. What 4-1 you have? My mac 4-1 lets me to remove the old filter.
  17. k-moe
    Oh, you made that? No wonder it looks a bit different from the kit.
    Very well done.
  18. Polock
    is that blue from a Toyota FJ ?
    Prototrak lpm mill ?
  19. dirtmax
    dirtmax Member
    BC, Canada
    I guess you'll have to figure out if you need more (or less) then 2.5 liters of oil.
    This works with any kind of oil, ya? Like for example I'm using Rotella T.
  20. desmotom
    Canada MB
    Painted it before the FJ ever existed!
    HAAS Mill and lathe.
  21. dirtmax
    dirtmax Member
    BC, Canada
    Honestly, I have no clue. My guess is it's mac. PO must have banged it somehow, now is off centre and filter cap starts pressing on one of the pipes as soon as I start unbolting it.
    ...now I'm thinking I could hit filter cap back as I'm unbolting.
    But I definitely like that design better.
  22. desmotom
    Canada MB
    image.jpeg Started the disassembly this weekend.....
  23. desmotom
    Canada MB
    finished up rear sets today, now have to mount and fab linkage. more pics to come! IMG_1387.JPG
    TheCrazyGnat likes this.
  24. MiGhost
    MiGhost Well-Known Member
    You did know that fancy machine work requires multiple copies to be made for members, Correct?;)
    Nice looking metalwork. Wish I had the room to set my machines up again.
    ~Ghost
    desmotom, TheCrazyGnat and k-moe like this.
  25. k-moe
    I wish I had the money (and space) for more than my little Atlas lathe. A milling machine would be fun to make chips on.
  26. MiGhost
    Had to let the shop, and big machines go in 03 due to the divorce, 08 pretty much wiped me out.
    Been slowly trying to rebuild a small shop since.
    ~Ghost
  27. desmotom
    Canada MB
    Wish I had machines at home...I have a 1800 sqft shop and would love to have a mill and lathe!
  28. Polock
    you sir are a knurling sob
    here's two quickie ideas for lunch time some day. brake rod and brake stay arm
  29. desmotom
    Canada MB
    Nice! I like a challenge!!
  30. MiGhost
    I am starting back up small using a couple chinese machines (Sieg X2, Big Dog 7X14). They are cheap and need a bit of work to dial them in properly. But space is limited at the moment. The bridgeport and 10" atlas were nice but way more than I needed for what I was doing with them.
    Got tired of shops quoting $250 set up fees for a $20 part. A simple We don't do small jobs would have worked just as well.
    ~Ghost
  31. desmotom
    Canada MB
    image.jpeg Security silicone? SIN #s engraved everywhere too.
  32. k-moe
    Someone loved their things sooooo much.
  33. desmotom
    Canada MB
    image.jpeg Hmmm....
  34. chacal
    That's better than just getting laughed at, which is pretty much the norm down here.........
  35. MiGhost
    BTDT!
  36. k-moe
    Usually $20 parts only cost $20 when you make a few hundred (or more) of them in each production run.
  37. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    BTDT?
  38. TheCrazyGnat
    Central PA
    Been there, done that?
  39. MiGhost
    And we have a winner!:D
  40. desmotom
    Canada MB
    finished clip ons, they are a little long right now, will trim once I am happy with length. Ordered new speedo and signal lights! Need to finish up rear set linkage then a complete tear down and start on the wiring. I want to do a minimal wiring job (cliché), I have a spare botched harness from a donor bike that I will use connectors from. Would like to put the larger rotors on from the 750 seca, might be a pain in the .... IMG_1420.JPG
  41. MiGhost
    Larger rotors = relocated calipers. I am sure you can handle that.
    For Reference:
    http://www.metalgear.com.au/
    650 Seca Rotors: XJ650R
    Measurements (mm)
    Outside Diameter
    267
    Inside Diameter 64
    Bolt Hole Circumference 80
    Bolt Hole Quantity 6
    Bolt Hole Size 8.5
    Thickness 5.0
    Minimum Thickness 4.5
    Offset 18.0
    750 Seca Rotors: XJ750R
    Measurements (mm)
    Outside Diameter
    298
    Inside Diameter 64
    Bolt Hole Size 8.5
    Thickness 5.0
    Offset 18.0
    ~Ghost
  42. desmotom
    Canada MB
    image.jpeg Got the clip ons on to see how they fit and look...pretty good I think. Don't hit the tank either with factory stops.
  43. desmotom
    Canada MB
    image.jpeg Think that will work. Will make a new one that will bolt from behind to attach to fork, and add some sexy to it! I'll probably 3D print the final model to make sure I like it before making chips.
  44. MiGhost
    As long as the calipers run true with the disc! Looks good!
    ~Ghost
  45. desmotom
    Canada MB
    image.jpeg Looks good with the blue filter and larger discs
    chacal and TheCrazyGnat like this.
  46. chacal
    You could paint the mower blue, too............ :)
  47. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I see what looks like Craftsman on it. But at first glance it looks a lot like a Toro Wheel Horse with a Kohler C20 in it?
    Just got done replacing the stator on mine, very proud to say I was able to remove everything withOUT pulling the horizontal motor!
    Apologies for the hi-jack and braggadocio. :confused:
  48. desmotom
    Canada MB
    It's a craftsman with a kohler!
    Started on the control linkage, and seat cowl. Getting sidelined now, my ranger was jealous and decided to drop a valve :(. Found another engine, just have to freshen it up. Never a dull moment
  49. desmotom
    Canada MB
    image.jpeg Finally got some time to work on the bike! Work and home has been so busy lately. Got the shift linkage mocked up, need to get shoulder bolts for the pivot points and prob gonna replace the threaded rod with a. Aluminum rod in the future. The brake side I have fab a bracket, but I am using the factory shaft and linkage.
  50. desmotom
    Canada MB
    haven't updated my project in a while, still working on it. starting the wiring soon (winter project). Anodizing all the parts I made also, and also have a few more parts to make. Ordered a new seat which should be here any day and a keyless ignition kit. Relocating project to my basement for the winter, gets too cold up here, and my shop takes a while to heat up. ranger is almost done though;)
