Cam Chain Tensioner
Discussion in 'XJ Technical Chat' started by Kingston, Dec 17, 2011.
  1. Kingston
    Kingston New Member
    Kingston, Ontario
    The Cam Chain Tensioner on my 1985 XJ 700Maxim, is it manual or automatic? How can you tell?
  2. bigfitz52
    According to the fiche, your bike has the automatic type.
    The manual type has an adjuster bolt and locknut sticking out of the (right) side as in the illustration below; yours will not have that. Yours should be smooth with a hex cap on the very tip; that's not a point of adjustment.
    This is the MANUAL TYPE:
  3. Kingston
    Kingston New Member
    Kingston, Ontario
    Thanks bigfitz, one less thing to worry about.
  4. bigfitz52
    Sorta. There's a procedure to "trick" the automatic tensioner into actually doing its job; I don't have it memorized because all of my XJs have the manual ones.
  5. hogfiddles
    rear fender has either been cut or is missing.
  6. hogfiddles
    Sure looks like that back rim has gone through a fire. That could be a big, quick clue as to the history! I guess it is possible that it is just mud and dirt, but it looks more like burned finish to me.
    Besides that, the color of the rims is wrong.
    Dave
  7. RickCoMatic
    The Manual coaxing of a Auto Tensioner is easy enough.
    You "Present" the Slack in front of the tensioner.
    Having an assistant "Drum" on the Tensioner while you manipulate the Chain, ... helps.
    Pull the Plugs
    Remove the Crank-cover and put a Wrench on the Flats.
    Smoothly turn the Engine over 4-times Clockwise beginning at the TDC Mark.
    Slowly come to a stop at the end of the 4 turns.
    Have the asst begin tapping on the end of the tensioner, ...
    Then, ...
    In a swift motion, ...
    Jack the Crank over ... Counter-clockwise ... presenting any slack in the Chain in front of the Tensioner.
    The Tensioner should react and extend to remove the slack.
