cam timing
Discussion in 'XJ Technical Chat' started by dave cutlan, Apr 12, 2017.
  1. dave cutlan
    dave cutlan New Member
    bristol uk
    Hi guys I hope someone can point me in the right direction, I have an xj750rl which I am told is quite a rare model mainly seen in Canada and Australia, I bought the bike in bits and have now put it back together, but it was making a funny wheezing noise so I decided to whip the head off and fit a new head gasket and at the same time do the cam shims. the only problem now is I didn't mark the cams well enough and cant get the cam timing right I have a Haynes manual for xj900 which is basically the same bike but that is not really helping me. perhaps if I knew the cam timing figures I could devise a way of fitting a timing wheel and measure when valves are opening and closing. any help would be good. cheers Dave.
    look on page 108 in haynes manual
    timing mark on pick up coil rotor to T
    arrows on cam hold down caps point to cam shaft which are marked with a dot
    there is more to it than that basics
    check your in box
