Can a cabled tach be Converted?
Discussion in 'XJ Technical Chat' started by rubikscube2007, Dec 30, 2008.
  1. rubikscube2007
    rubikscube2007 Member
    So I have a slight problem. A few friends and myself bought a junker bike to fix up and we've come to find that it's a 1981 XJ750R Seca engine stuck into a 1981 XJ650 Maxim body (we think, anyway).
    The gauge cluster has a cabled tach coming out of the bottom but from everything I can find the 750 Seca engines had electronic tachs. Is there anyway to make this tach work without replacing the gauge cluster completely? I do not have any experience working with tachs so if anyone has any ideas I'm willing to learn and try anything.
    Also, we're doing a Cafe Racer rebuild on this bike and so far it's coming along pretty well. I'll upload some pictures later because we'd enjoy any input we can get from you guys.
    Thanks,
    rubikscube2007
  2. Robert
    Sorry Rubik, you would have to replace the guts of the gauge to get it to work.
  3. SQLGuy
    SQLGuy Well-Known Member
    You can put an electronic tach on any XJ engine easily enough, but the other way around you're probably out of luck.
    If you can get an electronic XJ tach, you may be able to swap the guts in order to keep the same cluster. Otherwise you might just want to look for an aftermarket tach/speedo/etc.
  4. rubikscube2007
    What do I need to do to attach the electronic tach to it?
  5. TIMEtoRIDE
    You don't really need a tach because the engine is close to bulletproof anyhow.
    And it would help to post-up the chassis VIN number.
    and engine stamping #
    8O
  6. rubikscube2007
    lol. We'd actually considered just leaving it but we figure we'll fix it anyhow, if anything for the education of doing it.
    I think the VIN number is "4h7-106609".
    And there's a stamp on the front of the engine: 748cm. Is that the engine stamp?
  7. TIMEtoRIDE
    The steering neck has a white paper tag with a 17 digit #
    The motor stamp is near the clutch cable end.
    These numbers really help the Learned Ones here.
    An electric tach can be spliced into the orange coil wire- - me thinks. . .
  8. rubikscube2007
    Okay, I pulled the correct VIN number: JYA4H7006BA106609
    The motor stamp is: 15R-003438
  9. SQLGuy
    Sure enough, as you thought, the VIN indicates a 1981 XJ650. And, as you've noted from the front casting numbers, the engine is a 750... not sure of the year, though.
  10. rubikscube2007
    Awesome. lol. Out of curiosity, since Google did me no good, do motorcycles need a tachometer to be legal in the United States?
    If not, since it's a cafe racer mock up, how does everyone think a single hud with the speedo and odo in it would look? And does anyone know where to get a relatively cheap one?
  11. TheHound
    TheHound Active Member
    Scotia, NY
    You don't need a tach for inspection.
    I think a single round pod would look great.
    If you're going to trash the factory gauges you can buy aftermarket single round pods that have everything in one.
    ie tach, speedo, nuetral, oil, highbeam.
  12. chacal
  13. gitbox
    gitbox Member
    Replacing the mechanical tach with an electronic one is pretty easy. I put a 750 engine in my 650 and had to do it. I found the proper gauge cluster on ebay. It just needs a wire added from the tach to one of the ignition coils and some rewiring inside the headlight bucket. I can get you details if you want.
  14. WiseManSage
    WiseManSage New Member
    Armidale, NSW, Australia
    Im with all the guys on this one. A simple tacho should short you out. Very easy to wire up, usually has 3 or 4 wires coming from it - acc, earth, coil and some will have a wire that will connect to the headlight relay so when you turn ur head lights on its internal light will come on.
    I recommend a chrome 2" one would look great on the cafe racer. Most will come with some mounting brackets as well.
  15. jonnymaritime
    jonnymaritime Member
    Montreal QC
    Where would I purchase one ?
  16. WiseManSage
  17. rubikscube2007
    My XJ700N would be hostile toward that tach gauge. She's normally very happy in the 6000-7000 range.
  18. bigfitz52
  19. shangovi
    shangovi Member
    Burtonsville MD
    This is for gitbox - I could do with that info. I HAVE AN 81 Maxim 650 came with a mechanical tac - not working. I have an elecrical one but no idea how to hook it up :oops:
  20. moonfriedpotatoes
    moonfriedpotatoes Member
    Montana
    hey gitbox, could i get those details about hooking up an elec tach? i have the same issue (650 frame 750 motor). you can pm me or post for everyone's benefit.
  21. SQLGuy
    Well, the stock type ones take three wires:
    Brown = +12V switched and fused (like from the gauge lights)
    Black = Ground
    Gray = tach input signal from either coil drive wire
    The coils each have a two pin connector with one pin being 12V supply and the other pin going to a gray or orange wire that runs back to the TCI module. It's that gray or orange wire that the tach gets it's signal from.
    Aftermarket tachs may connect up the same way, or may use an inductive pickup to get their input from one of the spark plug wires.
  22. moonfriedpotatoes
    Montana
    so one would have to wire brown to the coil, and black to the frame (?), and splice the gray into the coil to tci wire ?
  23. SQLGuy
    No.
    The brown wire should be connected to other brown wires, like from the gauge lights. The red/white at the coil does have 12V switched, but it's also got a LOT of switching noise from the coils.
    Yes, the black would go to the frame, or to another black wire.
    The gray would get spliced into either the gray or orange from the TCI box.
