can anyone tell me how to remove the vacuum caps on my 82 Yamaha XJ650 intake manifold boot
Discussion in 'Hangout Lounge' started by Jerry Smith, Feb 27, 2021.
  1. Jerry Smith
    Jerry Smith New Member
    Branson, Mo
    can anyone tell me how to remove the vacuum caps on my 82 Yamaha XJ650 intake manifold? They're really hard to remove and I don't want to break them do they come all the way off?
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Remove the clips with some longnose pliers and then pull the caps off with the same pliers. If they are brittle with age just buy some more, they are only a couple of $ each.
    If you're not going to sync the carbs i would leave them in place then buy new for the sync and replace when the time comes.
  3. Dave in Ireland
    Ireland
    If you break them and need to use the bike, just cut an inch+ of rubber tubing, put it on and seal it with a short bolt smeared in Hylomar. Ideally put the clamp back on the tube and if possible use a fuel clamp on the bolted section.
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    In a pinch, clear vinyl tubing with one end sealed with a lighter and pliers.
    Dave in Ireland likes this.
  5. Toomanybikes
    Tsawwassen bc
    Your local auto parts store has vacuum caps in many sizes
  6. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I found the vinyl vacuum caps I bought at an auto parts store get really soft when the engine fully warmed on a hot day, and even with a clamp were loose. I was worried about air leak, so I reverted to the OEM ones. I believe XJ4ever sells them.
