Can belt dressing be used instead of high-tack spray?
Discussion in 'XJ Technical Chat' started by mwhite74, Apr 15, 2010.
  1. mwhite74
    mwhite74 Member
    Figured i'd ask this question... I have so many can's of stuff laying around. When putting a valve cover back on, could i use serpentine belt dressing instead of the high tack spray to *stick* the gasket to the valve cover? If I can save my self 10 bucks by asking a dumb question it's worth it right? :) thanks!
    Marcel
  2. seaguy
    seaguy Member
    Coastal,AL
    Don't hurt to try. I used permatex black silicone on my original and it doesn't leak a bit.
  3. RickCoMatic
    The Cam Cover is not supposed to be installed using Sealant.
    The Cover is designed to be Removable.
    The Gasket simply needs to be installed on the Cover and then: Oiled!.
    You install the Gasket in the Cover so it wont fall-out being put-on.
    Apply a coat of Oil to the Gasket Mating Surface.
    Apply a coat of Oil to the Cylinder Head.
    Position the Cover and Tighten-down ... s-l-o-w-l-y!
    The Gasket will Spread-Out as it compresses,
    Oil tight.
    I won't leak.
    It is an example of Precision Engineering.
    The Cam Cover Rubber Donuts apply enough force upon the Cover to prevent it from leaking.
    You shouldn't need to apply anything sticky or goo-pee to the Cam Cover at all.
    Just a little oil.
    Like putting a new battery in your watch.
    The Cover fits on nice and tight. Waterproof.
    Hold the RTV.
  4. mwhite74
    mwhite74 Member
    Cheers guys,
    I had no intention on making the cam cover non-removable :D, no such thing as a stupid question right? At any rate thanks for fielding another, next week should be fun!
    Mars
  5. junkmn
    junkmn Member
    Colorado
    If you think you need something to hold it in place use silicone grease.
