Can I fit a Seca II 650 Turbo engine in a 81 Maxim 650 frame?
Discussion in 'XJ Modifications' started by 1981MaximRider, Mar 26, 2015.
  1. 1981MaximRider
    1981MaximRider New Member
    Virginia
    Saw a Turbo 650 engine for sale with the turbo and wiring harness. Would it fit in my 81 XJ650 ?
    There is a Seca 650 Turbo, and a Seca II (non turbo, but there are turbo kits for everything). They are different machines with different engines. Which one are you looking at?
  3. FtUp
    FtUp Well-Known Member
    pacific northwest
    the seca engine should drop right into the maxim frame, the engines are identical. having the clearance and mounting points for the turbo, is another story. not sure what that entails.
    FU
    There will be foot control diffrences, and he will need the Turbo TCI and the Turbo airbox as well. The Trubo also has a sytems monitor, so he'll need to grab it and adapt it to the Maxim, or figure out the wiring so the Turbo TCI will play nice with the Maxim's safety circuits.
  5. FtUp
    pacific northwest
    well he said he is getting the wire harness, so all the maxims systems are out the door, and I imagine some of them will plug right in (kick stand switch, clutch switch, etc.).
    FU
  6. hogfiddles
    And he will have to figure out how to mount the turbo, the surge box, the collector box because it is different than the maxim, the carbs are different, different tubes to the carbs, different exhaust because of the turbo unit, etc....., and NO, the engines are NOT identical.
    BUT, in short.....the answer to the question "can it be done?" is YES. All it takes is money.......quite a fair bit of it, but yes.
    Now, there is a a build thread on here already from another member who turbo'd his 650 maxim. Do your homework and you'll find it. I'll take a quick look to see if I can find it, too-
    Dave F
  7. hogfiddles
  8. 1981MaximRider
    Virginia
    thanks guys,
    Was just curious if the engine will bolt in, mesh ok with the shaft drive, and have enough clearance for the Turbo and supporting hardware. I can figure out most of the other stuff. I just rebuilt this 650 Maxim about 2 yrs ago. I just saw the Turbo engine for sale on craigslist and thought to myself...hmmmmm that would be an interesting project.
    jmilliken likes this.
  9. vesparider
    vesparider Member
    douglass ks
    Yes its pretty much a bolt in. Bracket needs to be made for the turbo and some tabs are different on the frame.
    message me if you need more details.
  10. vesparider
    vesparider Member
    douglass ks
    Just realized Hogfiddles already posted a link to my pics and video
  11. chacal
    Nice job Vesparider.
  12. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Yeah. That's the craziest Vespa I ever saw! JK!
    Where is the intake going to go once you remove the pipe in picture three?
  13. vesparider
    vesparider Member
    douglass ks
    "Vespa" is a reference to my Motot Guzzi Rossa Sport I own.
    The "X" is the wastegate tube that on the Seca Turbo goes into a muffler. I just left vented to atmoshpere.
