Can somebody help a brother out ?
Discussion in 'XJ Technical Chat' started by danno, Apr 4, 2008.
  1. danno
    danno Member
    Union Springs,New York
    I need to source a new set of 1982 XJ 650 Maxim carb intake boots for a friend. I am looking for the engine to carb boots,as his are severely cracked. I replaced mine a few years ago,and can't for the life of me remember the name of the ebay seller that I purchased them from. I have searched ebay,but to no avail. A seller named georgefix sells boots,but I didn't find any for the 650 Maxim.I also tried Cirrius (I am sure I didn't spell that correctly)Consolidated in Canada,but still nothing.Any suggestions will be greatly appreciated!
  2. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    Bikebandit.com
  3. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    PM or Email chacal
  4. danno
    danno Member
    Thank you,guys! You are an awesome resource!!!
  5. chacal
    Here's what I got, in stock and ready to go!
    INTAKE MANIFOLDS AND ACCESSORY PIECES:
    HCP536SET4 OEM Yamaha rubber intake Manifold Boots, complete set of 4 intake manifold boots (2 left and 2 right). Manifolds only; you must order all accessory pieces (boot-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1982-3 XJ650 Maxim (except turbo) and all XJ750 models. Set of 4:
    $ 132.00
    HCP544 OEM intake manifold-to-head Gasket, used on all XJ650 (except turbo), all XJ700 non-X, and all XJ750 models.
    Each:
    $ 5.00
    HCP544SET4 OEM intake manifold-to-head Gasket, used on all XJ650 (except turbo), all XJ700 non-X, and all XJ750 models. Set of 4:
    $ 18.00
    r) OEM and reproduction Intake Manifold Mounting Bolts, both original and reproduction mounting bolts perfectly replace your originals. It's not a bad idea, at all, to replace these bolts whenever you change your manifolds. Use 2 bolts per manifold. And please be sure to use anti-sieze fluid when installing these bolts!!!!
    HCP548 OEM intake manifold boot-to-head Bolt, black alloy steel allen head hex-drive bolt. Use 2 per manifold, 8 per engine. Each:
    $ 1.20
    HCP548SET8 OEM intake manifold boot-to-head Bolt, black alloy steel allen head hex-drive bolt. Use 2 per manifold, 8 per engine. Set of 8:
    $ 8.50
    HCP80 Aftermarket intake manifold boot-to-head Bolt, natural finish alloy steel allen head hex-drive bolt. Features a small nylon thread patch, making this a self-locking bolt. Use 2 per manifold, 8 per engine. Each:
    $ 1.50
    HCP80SET8 Aftermarket intake manifold boot-to-head Bolt, natural finish alloy steel hex-drive bolt. Features a small nylon thread patch, making this a self-locking bolt. Use 2 per manifold, 8 per engine. Set of 8:
    $ 10.50
    HCP2423 Aftermarket intake manifold boot-to-head Bolt, bright 18-8 stainless steel allen head hex-drive bolt. Use 2 per manifold, 8 per engine. Each:
    $ 1.20
    HCP80SET8 Aftermarket intake manifold boot-to-head Bolt, bright 18-8 stainless steel hex-drive bolt. Use 2 per manifold, 8 per engine. Set of 8:
    $ 8.50
    HCP2423 Aftermarket intake manifold boot-to-head Bolt, black-oxide coated alloy steel allen head hex-drive bolt. Use 2 per manifold, 8 per engine. Each:
    $ 1.00
    HCP80SET8 Aftermarket intake manifold boot-to-head Bolt, black-oxide coated alloy steel hex-drive bolt. Use 2 per manifold, 8 per engine. Set of 8:
    $ 5.50
