can someone settle an argument for me
Discussion in 'Hangout Lounge' started by Rastacia, Jun 25, 2012.
  1. Rastacia
    Rastacia Member
    I say carb mixture screws turn out to richen as per factory pro website cv tuning.
    Mechanic ( race one at that and clever guy BUT) he says if the mixture screw is at the back of the carb its turn out to richen , but if its cylinder side of the carb ( like on our XJ's) then its turn in to richen.
    this has thrown me as I have read similar to both arguments on the web .
    I know my ZX6 mixture screw is airbox side and its out to richen . now I am running round in circles , help
  2. dmccoach
    dmccoach Member
    NE PA
    Out = richer - because the screw controls rate of gasoline flow through the pilot circuit...
  3. Bushy
    Bushy Active Member
    Th carbs on yours and mine are OUT to richen th mix. Dunno about th ones at th back of th carb ..
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    As far as i know, if it's on the air side, it's an air valve for the pilot circuit. (out is more air in is more fuel - less air)
    If it's on the cylinder side, like ours, it's out to richen, and in to lean it out.
  5. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    My 83 XJ750K out to enrich mixture, in to lean the mixture.
  6. MiGhost
    MiGhost Well-Known Member
    It makes no difference which side it is on. It is simply a metering screw that adjust the mixture either before, or after the fuel has been vaporized. Out will increase/richen the mixture. In will decrease/lean the mixture.
    Ghost
  7. MiCarl
    Generally speaking the Mechanic is wrong. In MOST cases a screw at the back is out=lean, at the front of carb out=rich.
