Can the '83 bikes (elec. tach) drive a mech tach?
Discussion in 'XJ Technical Chat' started by tosoutherncars, May 1, 2014.
  1. tosoutherncars
    tosoutherncars Member
    Ottawa, ON
    Hi Y'all,
    I had asked sorta the opposite question HERE, but perhaps I'm going at this backward.
    Do the '83 motors still have the port to drive a mechanical tach? Where would I look; on the front of the engine, between 2 and 3 I think I read somewhere?
    My end goal is to ditch the Atari, replace it with 'traditional' dual round gauges that look vaguely stock (i.e. not LED-lit mini gauges or something similar).
    TIA,
    Duncan
  2. Polock
  3. lacucaracha
    lacucaracha Member
    Napa, CA
    Not 100% sure on the port, I'm pretty sure if you look you'll either see a hole on the front of the engine, or it hasn't been drilled out. The 750 tach is electronic and looks much nicer, although they're only partial circles. I switched my 650 seca to electronic because I was tired of replacing the drive gear seal all the time. It's one less cable, too.
  4. MiCarl
    Much more to it than a port. There is a drive gear and all its associated bushings and hardware. The earlier exhaust camshafts had a worm gear that engaged the tach drive gear, not sure it's still there on the YICS engines.
    Bottom line: You're looking at a major retrofit.
  5. MiCarl
    If you're looking for round gauges snag a set off a YICS 550/650 Maxim. They used electronic Tachs.
  6. tosoutherncars
    Ottawa, ON
    Polock, I really don't like mini-gauges; and nice 4" aftermarket gauges (with wires, brackets and all assorted bobbins) would probably end up costing me about $500. I figured if a nice set of stock gauges (like those found on earlier Secas) could be retrofitted, I'd try that and save a few bucks.
    Carl, if XJ550 / 650 YICS bikes use electronic tachs, it must only be certain years - almost 100% of the ones I've seen have been mechanical (see for ex: this 1983 set): http://www.ebay.com/itm/1983-Yamaha-XJ5 ... 78&vxp=mtr
    But then here's a set of '81 dials, looks like the tach is electronic; http://www.ebay.com/itm/YAMAHA-XJ650-19 ... a0&vxp=mtr
    So confused. :p Ah well, may just buy a set, start staring at wiring diagrams, and see what happens...
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    the '82 650 maxim has a electronic tach. there are two sets on ebay...they're expensive.
  8. tosoutherncars
    Ottawa, ON
    Like the one I just posted, Rocs? (almost round, flattened bottom) Or a different model?
  9. MiCarl
    I was wrong, the 550 maxims appear to all be mechanical.
    The 82-83 650 & 750 Maxims use an electronic tach that look exactly like the round 550 ones you posted.
  10. midnightmoose
    midnightmoose Member
    York, PA
  11. hogfiddles
    The 550 maxim tach is mechanical.
    The earlier 650 maxim tach is mechanical
    The later 650 and 750 techs are electrical
    It's easy to tell in a pic as long as you can see the wires.... if there are wires coming from the back of the tach, it's electrical. If there is a 'speedo' type hub on the back of the tach, its mechanical.
    if you want to switch to a mechanical tach, you'll have t o switch the head......that means you'll possibly have to deal with switching to non-yics , too.
  12. tosoutherncars
    Ottawa, ON
    Well they all have wires coming out of the back, for the lights... But yes, the electronic ones have more wires, the mech ones just have two wires for the bulb.
    I've got a swap meet here in Ottawa tomorrow, first one of the season... I'll see if I can find anything appropriate there. If not, I think I'll either grab that Maxim cluster, or find an earlier XS cluster for the cans and the speedo, and swap in a modern tach.
    Either way, I'll try to remember to take some photos and throw them on here - there's surely no shortage of people who would like to get rid of their 'fishfinder', what an eyesore! (And that's coming from a guy who likes the 80s stuff!)
  13. MiGhost
    MiGhost Well-Known Member
    Forget about the wiring.
    The back of the tach with have a drive hub for the mechanical tach, or no drive hub for an electric tach. The ebay link in your other post shows the mechanincal tach with drive hub.
    All OEM speedos have a drive hub
    WARNING!!
    Be aware that replacing the atari with a standard guage cluster will result in great fun trying to figure out why the bike will not run if the wiring to the computer is not correctly bypassed!!!
    Ghost
  14. tosoutherncars
    Ottawa, ON
    I posted two links Ghost, which one are you talking about? Pretty sure this is the electro tach; http://www.ebay.com/itm/YAMAHA-XJ650-19 ... a0&vxp=mtr
    Yes, I realize that I'll have to make allowances for one or two things; the side stand sensor, etc. That said, it's not like there's a CPU to work around; just have to make sure that everything gets wired up straight.
  15. MiGhost
    Yes, That is the electrical tach. The other link posted showed the mechanical tach.
    Actually, There is a CPU in the atari, and approx 5-6 wires that need to be bypassed correctly or the bike will not run.
    Ghost
  16. hogfiddles
    "Well they all have wires coming out of the back, for the lights... But yes, the electronic ones have more wires, the mech ones just have two wires for the bulb. "
    Just like I said......
    .......If there is a 'speedo' type hub on the back of the tach, its mechanical.
