Cannot apply throttle
Discussion in 'XJ Technical Chat' started by PDNetzer, Jun 8, 2024.
  1. PDNetzer
    PDNetzer New Member
    Olympia, WA
    I rebuilt the carbs on my 1982 XJ750 Maxim and it starts and idles perfectly, but cannot rev it up. With just the choke it will Rev up to about 4500rpm. If I twist the throttle very slowly I can get it to Rev up to about 4500rpm. If I twist the throttle quickly, it kills the engine. I have my idler screws set at about 3 turns out and have tried other settings, but the same results. What am I doing wrong?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    are your throttle slides moving smoothly, these can be tested (with carbs off the bike) by blowing down the oval hole at the top of the intake side of the carb mouth, the slides should move up quickly and return a little slower.
    are the rubber diaphragms sealed correctly, at the carb hat?
  3. chris123
    chris123 Active Member
    Benicia, ca
    Valves recently adjusted?
  4. PDNetzer
    PDNetzer New Member
    Olympia, WA
    No, I have not touched the valves
  5. PDNetzer
    PDNetzer New Member
    Olympia, WA
    I had done the air test before putting them on the bike and they all looked correct. The rubber diaphragms all looked good and were seated properly with the notch in the casting.
    Brhatweed likes this.
  6. Brhatweed
    Brhatweed Active Member
    Mora MN
    And you have visually verified the main jets are completely clear and the emulsion tube pinholes are all open? How about the sealing washer at the bottom of the main jets where they meet the body itself and the float levels being set using a level surface? Did you remove the air jets under the diaphragm cover and if so did they go back into their correct locations? Believe it or not the service manual is WRONG on their placement and this is detailed in the carburetor section of this forum.
    PDNetzer likes this.
  7. PDNetzer
    PDNetzer New Member
    Olympia, WA
  8. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Is the throttle cable connected to enrichment and enrichment cable to throttle?
    Simmy and Brhatweed like this.
  9. Timbox
    Timbox Well-Known Member
    Starving for fuel? Not too sure how much fuel you have in the tank? Is the petcock okay? Turn it to prime and see if the issue goes away. By the Vid, are you showing us without showing us the cables are in the correct place?
    Sounds like a good job cleaning the carbs are the bike fires right up.
  10. PDNetzer
    PDNetzer New Member
    Olympia, WA
  11. PDNetzer
    PDNetzer New Member
    Olympia, WA
  12. PDNetzer
    PDNetzer New Member
    Olympia, WA
  13. Oblivion
    Oblivion Active Member
    Northeast Illinois
    How long has it been? If you don't know, check/adjust them.
  14. Rooster53
