cannot find fuse box + light problems
Discussion in 'XJ Technical Chat' started by frenchtracker, Jan 27, 2015.
  1. frenchtracker
    frenchtracker Member
    vancouver
    I have an 1981 xj650 maxim.
    tore the bike appartment and cannot find the fuse box. Having problems with rear after market brake light it's constantly on and when brakes are applied it doesn't get brighter
    Also the front light stopped working but I've read it needs to be correctly in its casing with spring to work?
    Some please help!!
  2. Kris Taylor
    Kris Taylor Member
    Jacksonville,Fl
    Your fuse box is located under the seat on top of the airbox.
  3. JaiFer
    JaiFer Member
    Northern Ontario
    Since you are having a number of electrical issues I would suggest that you get a Multimeter or a circuit tester to check your connections. You say your front light isn't working, do you mean your headlamp? Is neither front or rear brake switch working? And did you find your fusebox under the seat?
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    If his bike has one (spaghetti factor). The headlight should come on when you start your bike. Briefly describe how the aftermarket brake wiring is connected; maybe a member(s) can help.
    Gary H.
  5. frenchtracker
    vancouver
    Yeah I mean the headlamp. I unscrew that spring that goes in lamp maybe it needs to be all put together properly Apperently it has too iv read somewhere for it to turn on..
    signal lights work but don't flash .. I've been told that bike has to be running for them to flash..
    The brake light comes on I think it's just the running light and when I apply the brakes they don't get any brighter
    also fusebox isn't there
  6. k-moe
    You bought someone's project. There is no way to know how it was wired, or if it was ever working properly. You have two options: Buy an unmolested wiring harness, or get a service manual and start tracing wires to figure out the mess that you have.
    engraverwilliam likes this.
  7. frenchtracker
    vancouver
    I bought it all stock.. lights were all working until I ripped it apart..
  8. hogfiddles
    You probably hooked the wires up wrong to the tail light. The black is the ground-- try swapping the other two leads.
    Headlight-- light will only work once the engine fires and the "latch" is made. Light does NOT need to be all assemble first. There are three wires to the bulb-- ground, low beam, high beam. Start your bike and check both high and low to see if one or the other works. If neither, time to find the fuse-- or if its spaghetti, may they've all been cut out and bypassed (eeeeeesh)
    Turn signals may sometimes flash a little with just they key on. But usually the bike needs to be running, and even then, they may not always flash if the idle speed drops too low.
    frenchtracker likes this.
  9. rocs82650
    Middle Tennessee
    If this is true the fuse box should be under the seat, as Kris stated, on top of the air box. All of the electricals should be fused. Imo you should start there.
    Gary H.
  10. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I had issues last year with the sockets for the brake lights somehow grounding themselves out and causing the brake lights to stay on. New sockets from an auto parts store fixed that one.
  11. hogfiddles
    The EASIEST thing is to just swap the leads and see if that solves the problem . If it does, it solved. If it doesn't, THEN you can tear in deeper....
  12. frenchtracker
    vancouver
    Finally fired er up and got the brake to go dimmer when brakes were applied.. it's a start!
  13. frenchtracker
    vancouver
    Front light turnt on soon as I got her started thanks!
    Think they must be all hardwired.. not sure why.. whats the worst thing that could happen..
    brake light Seems to be getting there. . It's going dimmer when applying brakes but maybe just cuz isn't revd up and not warmed up..[/QUOTE]
  14. hogfiddles
    Brakes need to get BRIGHTER when applying the brakes. Check your wires!!!
    I told you the headlight will only be able to come on once it fires.... The 650 has a relay or "latch". Other bikes are wired differently.
