Cant get past 3rd gear
Discussion in 'XJ Technical Chat' started by mustangman9250, Sep 16, 2012.
  1. mustangman9250
    mustangman9250 New Member
    Eugene, Oregon
    So on the way home from work tonight i stopped to fill up the seca 750.bike is running great but i cant get past 3rd gear.bike has 31k on it. Im running castrol 20/50. Any thoughts on the possibilitys i order a manual but i haven't gotten it yet.
  2. Polock
    you need a longer road
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    It physically won't shift into third gear or you don't have the power to get it past third gear? You might have a worn transmission fork or something has broken and is jamming it.
  4. mustangman9250
    Eugene, Oregon
    It physically wont go into 3rd. But if its on the center stand. I can rock the wheel and i can shift thru all five gears.
  5. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Could be the clutch. Are you using motorcycle specific oil? Automotive oil is bad news in these bikes. It causes all kinds of problems with the clutch. .
  6. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    UH OH, PO is at it again....but I confess, that was my first thought too....lol
    Be VERY leery about riding a bike that isn't shifting all the way through the gears.....I have seen gearboxes at the track cause major problems(read:crash) when the offending piece relocates and locks the rear wheel. If it's not your clutch which I kind of doubt, check the shift shaft for lateral play and see how it shifts when you hold it to one end.....otherwise, you migh be looking at a weekend project to split the cases to straighten it out.
    jeff
