CARB BOOTS (Maxim)
Discussion in 'XJ Technical Chat' started by kerstingm, Nov 12, 2007.
  1. kerstingm
    kerstingm Member
    Columbus Oh
    Does anybody have or know where I can get some intake boots?
    for a 81 650
  2. PSteele
    PSteele Member
    Nova Scotia, Canada
    Best place I know is the dealer. Ours will supply a set of 4 for around $100, new with gaskets. Just be careful taking them out - mine has frozen cap screws. They are notoriously weak according to the guys on this forum and could be costly if broken off. Check my post on the topic:
    http://xjbikes.com/Forums/viewtopic/t=5767.html
    Good luck with your manifolds.
  3. chacal
    I carry these boots (and related accessory pieces, including the bolts) in stock, which you can review at:
    http://www.xjbikes.com/Forums/viewtopic ... t=120.html
    HCP535LH OEM Yamaha rubber intake Manifold Boot, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (boot-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-81 XJ650 Maxim, 650 Midnight Maxim, and 1982 XJ650 Seca (not turbo) models. Each:
    HCP536RH OEM Yamaha rubber intake Manifold Boot, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (boot-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-83 XJ650 Maxim, 650 Midnight Maxim, and 1982 XJ650 Seca (not turbo) models. Each:
    HCP535SET4 OEM Yamaha rubber intake Manifold Boots, complete set of 4 intake manifold boots (2 left and 2 right). Manifolds only; you must order all accessory pieces (boot-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-81 XJ650 Maxim, 650 Midnight Maxim, and 1982 XJ650 Seca (not turbo) models. Set of 4:
    HCP77 Reproduction Yamaha rubber intake Manifold Boots, complete set of 4 intake manifold boots (2 left and 2 right). OEM quality at a better price! Includes a set of 4 manifold-to-head gaskets. Fits all 1980-81 XJ650 Maxim, 650 Midnight Maxim, and 1982 XJ650 Seca (not turbo) models. Set of 4:
    Stumplifter and Jetfixer like this.
  4. kerstingm
    kerstingm Member
    Columbus Oh
    My bag I need the boots going into the filter box
  5. chacal
    Here they are!:
    af3) OEM and reproduction Air Cleaner Box-to-Carb Rubber Joint or "Boot", both original and reproduction individual boots and complete sets are offered to allow you to replace cracked, dry-rotted, vacuum-leaking (making carb tuning impossible......) or missing originals. These are the boots that run from the air cleaner box to the rear of the carbs!
    HCP559 Air Cleaner Box-to-Carb Rubber Boot, for all XJ650 (except Turbo) models, each:
    HCP559SET4 Air Cleaner Box-to-Carb Rubber Boots, set of 4:
    af4) OEM air cleaner-to-carb boot Metal Clamping Ring, includes the cinching screw. These are used on the carb end of the boot only.
    HCP565 OEM air cleaner boot Metal Clamping Ring, for all XJ550, XJ650 (except Turbo), XJ700 non-X, and XJ750 models, each:
    HCP565SET4 air cleaner boot Metal Clamping Ring, set of 4:
    rocs82650, Stumplifter and Jetfixer like this.
  6. kerstingm
    kerstingm Member
    Columbus Oh
    Thanks. Is there a link where I can buy them?
  7. chacal
  8. kerstingm
    kerstingm Member
    Columbus Oh
    Thanks found the info, I'll get back to you after I get my list together.
  9. Jamerz
    Jamerz New Member
    winnipeg
    I know this is an old thread. But I'm looking for the carb intake boots for a 82' maxim 650? Any help?
  10. TheCrazyGnat
    Central PA
    Chacal sells those as well (link at the top right of the page):
    HCP559 OEM Air Cleaner Box-to-Carb Rubber BOOT, for all XJ650 (except Turbo) models
    HCP559SET4 OEM Air Cleaner Box-to-Carb Rubber BOOTS, set of 4
    HCP1205 Aftermarket Air Cleaner Box-to-Carb Rubber BOOT, exact reproduction of the original, for all XJ650 (except Turbo) models
    HCP1205SET4 Aftermarket Air Cleaner Box-to-Carb Rubber BOOTS, set of 4
    Stumplifter likes this.
  11. Jetfixer
    Yep I got a set from xj4ever real nice and so easy to install as my old ones were rock hard. Highly recommended :)
  12. joejr2
    Santa Fe,NM
    Try ebay. Search under yamaha xj650 parts. salvage guys sell random collections of parts and sometimes
    intake boots are part of the batch. Do a thorough search and you might turn some up.
    JHM likes this.
  13. k-moe
    Used ones are not often worth buying.
  14. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
  15. hogfiddles
    SO DOES XJ4EVER
    When you're all done farting around with your cheaper set, get sent the wrong parts, find out they don't fit, send them back, and go through it all over again.... Just to find out they are junk-----
    Just get them from Len, and be riding again.
    Lierre, Stumplifter and Jetfixer like this.
  16. Jetfixer
    ^^^^++++1 True!!!!
  17. chacal
    We no longer offer the reproduction intake manifolds for the XJ650/XJ750 models as we've had too many significant failures with them. They all come from one source (there is only ONE manufacturer of these particular reproduction/aftermarket manifolds) and every one of them that you see being offered for sale.....whether on individual websites, shops, eBay, Amazon, etc. ALL come from that one source, and ALL of them have quality issues (they are simply not made properly),
    We still have the OEM manifolds available.....they are much more expensive than the repro manifolds....but they'll last 20+ years just like the originals did. With these particular repro manifolds, you might only get 20 DAYS use out of them..........
    BTW, the above applies ONLY to the XJ60/XJ750 intake manifolds. The aftermarket/reproduction XJ550 and XJ1100 intake manifolds are an oem-equivalent quality product.
    Jetfixer likes this.
  18. Jetfixer
    This WHY we need to order from xj4ever....he only sells the best and will stand by his product.. Some ebay sellers are honest, some not so much. my motto Buy the best cry once... better than spending $$ and have to keep spending money to get part that might work or not. Thanks Chacal
  19. Jamerz
    Jamerz New Member
    winnipeg
    Wow, thanks for all the replies guys! I think I will end up ordering some new ones over the winter. A guy at a local shop showed me how to "patch" them with some black magic and an inner tube. I was going to try that for now but it looks like I'm going to have to change some piston rings too...looks like a bigger parts list/budget is in order.
  20. Wagy
    Wagy Active Member
    PA
    While we are on the subject, my boots are in good shape , but they wont be for much longer if I dont find a way to get those SOB's back in their spots. Been farting with just the first one for hours with no luck and getting close to tearing it by prying. I would like someone to give me the secret or at least tricks and tips on installing box -to-carb rubber boots after the air box and carbs are already on ? Anyone, Any help ?
  21. k-moe
    Hairdryer. Warm them up. Phillips screwdriver to help push them on. Cursing. Beer.
    Nuch and Yardawg like this.
  22. Yardawg
    Yardawg Active Member
    Hatch NM
    And more beer and cursing if needed!
  23. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    K-Moe beat me to the "Post Reply" button! Ha Ha... Heat! Warm them up and they will soften and be more "bendy" and pliable. Though most of the North East is pretty warm right now maybe it's cool in your garage??? Also, put a light coat of silicone grease on the outer lip of each carb neck if need be. It will help the boots to slip on. DO not use vaseline as it is petroleum based and will eat your rubber. Also Make sure your air box is not screwed tightly in place. Let it "float."
    Yardawg likes this.
  24. Wagy
    Wagy Active Member
    PA
    thanks guys, been trying the warming , cursing, 3-n-1 oil , definatley going to try more beer !!!
  25. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Also keep the carb to head boot clamps loose.
    Gary H.
  26. DoubleTigerLefty
    DoubleTigerLefty Member
    coquitlam
    I'm just going to ressurect this for a moment or two, because i got a chance to get a set of xj750 seca mounting boots, carb-to-head. But i have a 81 xj650 maxim.
    Any chance they'll work?
  27. k-moe
    Nope. You have a non-YICS engine. Only two of the intake boots from the 750 will fit.
  28. waldreps
    waldreps Active Member
    Henning, MN
    Why don't whoever makes the XJ550 and XJ1100 aftermarket ones make some XJ650 ones? If they know how and are making quality products for some, can't they make quality products for the other models? Or is there something really special about the XJ650 ones that are hard to duplicate?
  29. k-moe
    Unfortunately the reproductions of the 650 (and the 750) intake boots have had a few inexcusable (my opinion) failures, which is why Chacal no longer carries them. You can roll the dice on a set if you like; they're on Ebay all-day-long.
    The set I bought (prior to the failures becoming evident) are still working well, but will be replacing them with OEM if they do fail.
    I think the trouble is not a matter of being difficult to make correctly, but being difficult to make correctly and still cost less than the OEM boots.
    A few years ago (like 5?) there were no options for new intake boots from anyone. New Old Stock was as good as it got. As demand increases (and it will) more quality options will become available.
  30. waldreps
    Henning, MN
    Fortunately, I don't need any but it just seems odd that the reproductions for some models are good quality and other models aren't. I was just wondering out loud.
  31. chacal
    It's a long story..........maybe someday there will be a happy ending. K-moe has hit the nail on the head, with increased demand will hopefully bring more options.
    Jetfixer and waldreps like this.
