Carb bowls not filling
Discussion in 'XJ Technical Chat' started by panther9706, Jun 30, 2014.
  1. panther9706
    panther9706 New Member
    manchester nh
    My carb bowls will not fill on my '82 seca 650. i am getting fuel all the way down to the carbs but the bowls will not fill with the petcock on prime. Could this be some kind of vapor lock? Any help would be great.
  2. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Sounds more like blockage....have you opened your bowl drain screws to verify there is no fuel in them ????
  3. panther9706
    manchester nh
    I checked the no1 carb and there was nothing
  4. hogfiddles
    -Float needles are stuck shut
    -fuel rail is clogged, often at the "T"
    -tank vent in the cap is plugged creating a vacuum
    That keeps fuel from flowing
    Check those and let us know what you find
  5. panther9706
    manchester nh
    I did try it with the tank open with no luck, also where in the fuel tubes should i look i just had the carbs apart ant there was no obstruction in the fuel tubes
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I would look for some blockage in the fuel line or filter, if you have one, since it would be unusual for all of the needle valves to be stuck. You might even blow through the fuel line to see if it is blocked. Just don't swallow the gas :oops:
    Once when I was cleaning the carbs I was able to force gas through the carbs using a primer bulb off of an outboard motor fuel line. But if you have to force gas into the carbs then you probably do have problems with the floats and needles.
  7. RobbieRobot
    RobbieRobot Member
    North Yorkshire, England
    Have you had the carbs apart? It is very easy to re-fit the floats upside down.
