Carb cleaner in gas..
Discussion in 'XJ Technical Chat' started by Ribo, Nov 12, 2014.
  1. Ribo
    Ribo Prefectionist
    So someone mentioned to be that it might be good to put some carb cleaner in my gas.
    Although the bike is running well I do have an idle issue where my sweet spot on the choke is microscopic.
    Can I get some advice on if this is a good idea or what other gas additives are worthwhile and/or not damaging to these antique bikes.
    R./
    ( XJ650 Maxim 1981 )
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Don't put carb cleaner in the gas. Use a fuel additive like Stabil or Seafoam. I've used Stabil but I prefer and use Seafoam now.
    Gary H.
  3. Ribo
    Ribo Prefectionist
    What's the best process with the sea foam - can I just pour the whole can in a almost full tank? Do I need to bypass the vacuum (i.e. petcock on PRI).
    Should i expect the bike to smoke while it's working?
  4. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    No!
    Do not pour the entire bottle in. You only need 3-5 ounces for a few gallons of fuel. The only way I'd dump an entire bottle in my tank would be if it were in my Suburban's 42 gallon tank.
    The bottle should have a note as to how much to add per gallon of fuel.
    It may take multiple treatments. But it will start to clear up the fuel passages, if they're not completely clogged.
  5. Ribo
    Ribo Prefectionist
    Oh right - read the label - damn it I always forget that ;)
    Should I expect the bike to do anything unusual with this stuff in it - besides start to run better? Smoke? What about my fuel filter and vacuum?
  6. wink1018
    Muncy, Pennsylvania
    It should not smoke when added to fuel. That mostly happens when it's placed in the intake via vacuum hose or through the carb.
  7. Polock
    are you going to ride it or is this for the winter? do you even have a winter there?
  8. rocs82650
    Middle Tennessee
    Buy inexpensive liquid measuring cup (dollar tree) for easy measuring. One ounce per gallon (it's on the can). Like wink said 3 - 5 ounces every other tank full or so. A can holds 16 ounces (i think). The biggest differences i've seen is how much smoother she runs and how the fuel burns when i check the plugs. Make sure you're getting Seafoam fuel additive and not Seafoam penetrating fluid or Seafoam carbon cleaner. Imo they're all good products. Hope this helps.
    Gary H.
    P.S. - imo put in gas tank only. That's all it'll need.
  9. Ribo
    Ribo Prefectionist
    Sorry for the stupid questions - just looking for easy answers. I read the can and added it - seems to have improved things already even just on a 10 min ride.
    Yes Polock we do have a winter in Virginia :) - quite hash actually. I'm trying to get as much riding in as I can before the snow hits. Do you recommend using this differently for storing the bike over winter?
  10. rocs82650
    Middle Tennessee
    Stupid questions don't exist here (unless we're poking fun with one another). The can should tell you how much to use for longer storage.
    Gary H.
  11. Polock
    i don't think seafoam is for storage, you want sta-bil or i've used quality 2 stroke oil.
  12. FtUp
    FtUp Well-Known Member
    pacific northwest
  13. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    I think of Seafoam as preventative medicine, not a cure. Take your carbs to the "Church Of Clean" then use Seafoam as holy water to keep them free of sin.
    Polock, head a 100 miles North and you'll see what winter is.
    "Hi, boys and girls. Can you say...Lake Effect?"
  14. Ribo
    Ribo Prefectionist
  15. rocs82650
    Middle Tennessee
    Exactly.
    Gary H.
  16. Ribo
    Ribo Prefectionist
    If I wanted a motorcycle free of sin I'd buy a Harley...
  17. rocs82650
    Middle Tennessee
    I've never rode one so i wouldn't know. I'm not a band wagon type dude (not saying you are). I try not to knock things i haven't tried in order to establish my own opinion. A well built bike is a well built bike. I work in construction around some long toothed harley dudes. Some have stated they still have and ride their jap bikes. Enough said.
    Gary H.
  18. Ribo
    Ribo Prefectionist
    Just making a joke. I don't have a lot of time for Harleys personally but each to their own.
  19. hogfiddles
    You CAN expect some smoke as impurities and junk get flushed through and burn up, so don't be surprised if you do get some----
    5 inches of snow the other night.... Nope, not out on any of the bikes this weekend---
  20. Ribo
    Ribo Prefectionist
    Yeah I got a little bit and it really seamed to work - added it - ran the bike - saw some white-ish smoke which stopped after about 2 mins, bike runs better now.
    Well - whatdoyaknow!
  21. hogfiddles
    That would most Likely have been some water the got dispersed then burned out..... Usually garbage stuff burns blackish
