Carb exchange from 750 to 650
Discussion in 'XJ Technical Chat' started by OpaJim, Aug 1, 2007.
  1. OpaJim
    OpaJim New Member
    Mena, AR
    Hi All,
    I bought an XJ650LH, Midnight Maxim, with incomplete carbs
    and have not yet scrounged up enough parts to build up a
    complete set for it.
    It has a 4-1 exhaust that I can't identiy but I have been told
    that it "looks" like a Kerker. I have a foam UNI air filter for it.
    My 750 Seca has a broken clutch, so while it is down, could I
    take the 750 carbs and put them on the Midnight and have any
    chance at all that they could be adjusted to run right? Would it
    be a waste of time?
    Some one out there knows. :D
    Jim
    Mena, AR
  2. RickCoMatic
    You can't just swap 'em on there.
    The Jetting is all different.
  3. OpaJim
    OpaJim New Member
    Mena, AR
    Thanks Rick,
    I was thinking that since it will have less back pressure
    from the 4-1 and maybe more intake air with the UNI filter
    that I might get away with the larger jets in the 750 carbs.
    The main jet size will increase from 110 to 120, but it may
    not be possible to tweak it in. I have a 650 Seca so I guess
    I could try those carbs?
    Jim
    Mena, AR
  4. Robert
    I'm going to politely disagree with you on this one Rick.
    Jetting is a bit rich for the Max but it will swap in. If you swap the jets (I've done this already), all the rest of the parts work just fine. I would suggest you keep sniping at flea-bay until you find the carbs you need (which shouldn't be that hard, I see them regularly). When your done, swap out your jets to make the carbs ready for your 750.
  5. RickCoMatic
    That's what I actually meant.
    Sorry it wasn't clearer.
    I've been writing short-form; lately.
    Practicing for Postings of 25 words or less.
    My bad.
