Carb float levels
Discussion in 'XJ Technical Chat' started by pjwilkinson, Mar 21, 2008.
  1. pjwilkinson
    pjwilkinson New Member
    Indiana
    Are there any X-er Wizards out there? I am new to this site. Have had my 1986 Maxium-X since new. I let it sit a little too long and the carbs gunked up. Not the first time I've had to clean them up. My question is this. I know that my floats levels are not correct, don't ask why :oops: Does someone have the specs on this and maybe a picture from a service manual you could post?
    Also I notice a lot of people talking about a XJCD. Is that some kind of manual that's available and if so where to order?
    Thanks for any assistance anyone provides.
  2. Nick
    Nick Member
    Vernon, BC Canada
    Welcome to the site pjwilkinson
    Taken from the XJCD manual for the XJ750X & XJ700X.......
    Float Height Adjustment:
    Hold the carburetor in an upside down position.
    Incline the carburetor at 60* ~ 70* (so that the end of the float valve does not hang down as a result of float weight.
    Measure the distance from the mating surface of the float chamber (gasket removed) to the top of the float.
    NOTE: The float should be just resting on, but not depressing, the spring loaded inlet needle.
    Float Height: 17.5 +/- 1.0 mm (0.69 +/- 0.04 in)
    Fuel Level Adjustment:
    Measurement Steps
    Place motorcycle on a level surface.
    Use a garage jack under the engine to ensure that the carburetor is positioned vertically.
    Attach fuel level guage to the drain nozzle.
    Losen the drain screw and start the engine.
    Check the fuel level, one carb at a time.
    Fuel Level: 3.0 +/- 1.0mm (0.12 +/- 0.04 in) below the carburetor body.
    See this link for some pictures..... http://www.xjbikes.com/Forums/viewtopic/t=3360.html
    The following info is from Dave's Yamaha XJ page at ....... http://members.tripod.com/dave_jack/id47.htm
    Want one?? Ok follow these instructions and we will get one to you ASAP.
    MAKE SURE YOU INCLUDE YOUR FULL RETURN MAILING ADDRESS WITH YOUR PAYMENT!!! (We can't read minds)
    Please also confirm your order by E-mail to the person you are ordering from.
    For the XJ CDv4.0 :
    If you live in the United States, Send US$10.00 to:
    Brad Bowen ( xj700x @ netzero. com )
    4531 River Rd
    Arlington VT 05250
    If you live in the Australasia / South Pacific region Then send New Zealand
    (NZD) $15.00 within New Zealand or NZ$18.00 overseas to,
    Dave Jackson ( d_jack @ xtra. co. nz )
    23 Taylor Street
    Timaru 7910
    New Zealand
    Anywhere else in the world, send US$10.00, CDN$10.00, 8.00 euros or
    5 GB pounds to:
    Dwayne Verhey ( verhey @ surenet. net )
    Cottage Lane, RR#3
    Huntsville, Ontario
    P1H 2J4
    CANADA
    AGAIN, MAKE SURE YOU INCLUDE YOUR FULL RETURN MAILING ADDRESS WITH YOUR PAYMENT!!!
  3. simona
    simona Member
    Toronto
