carb plungers
Discussion in 'XJ Technical Chat' started by mrdawson, Sep 12, 2015.
  1. mrdawson
    mrdawson Active Member
    Wisconsin
    Wanting to dip my carbs... Have everything pretty much apart besides taking springs off, shafts out, and enrichment plungers removed.
    Can't really just fit a crescent in there to undo this... Is it OK to just push that black piece up to get at that nut? Or does that ruin it? Or does that even need to come off before dipping?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Just be careful and pop the rubber cap off and use a 10mm socket on the nut.
  3. hogfiddles
    Carefully pry it up and over the lip, don't damage the brass lip, though.. If they are nice and soft, reuse them but if they have hardened, throw them away and order replacements.
  4. mrdawson
    Wisconsin
    Thanks again
  5. Takencareofbusiness
    Takencareofbusiness Member
    North Vancouver BC
    mrdawson,
    You do know who to order these parts from don't you??.
    The man that needs no introduction and will completely service all of your XJ needs.
    I' ll give you a hint if you don't know.
    ^^^^^^^^ look up in the right hand corner.^^^^^^^^^
  6. mrdawson
    Wisconsin
    Yes, I have already been in touch with him. Just wanted to make sure this was the proper approach to getting this thing apart.
