carb question
Discussion in 'XJ Technical Chat' started by temperingloser, Apr 23, 2013.
  1. temperingloser
    temperingloser New Member
    paola ks
    so i was cleaning the carbs and went to take off float needle and ratchet slipped and i busted the float mount and seen some carb bodies on ebay and was wondering if a carb body from an 81 xj650 seca would work on an 82 xj750 maxim
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    The carb body should work from a 750, make sure that you use the right needle and jets. Also make sure that it is the same carb body position. If you go into breaking a rack might as well replace fuel shaft seals.
    Good luck.
  3. jason191918
    jason191918 Member
    Weston, WI
    i used marine jb weld to fix mine. worked awesome.
