Carb Quiz: identify these carbs...
Discussion in 'XJ Technical Chat' started by LarryMc, Sep 12, 2018.
  1. LarryMc
    LarryMc Active Member
    Lakewood, WA
    I know these are Mikuni flat slides.
    Can anyone provide any additional information on these? Screenshot_20180912-152005_Instagram.jpg
  2. Jetfixer
    These look like my buddies 1100 maxim that use KZ1200 carbs
  3. Toomanybikes
    Tsawwassen bc
    Flat slide Mikuni ... late model Suzuki 600/750
  4. Simmy
    Mikuni RS34
  5. hogfiddles
    On an xj550, and pods
  6. SpearChucker
    SpearChucker Active Member
    Prince George, BC, Canada
    You know you guys are kinda scary :Blackalien
    Stumplifter likes this.
  7. LarryMc
    Lakewood, WA
    I've been trying to contact the owner or builder to see how these worked on the bike and get any other pertinent information. Nothing.
    My guess is they are BST29SS carbs off a 1995 GSF250 Bandit which put out 45 HP.
    After looking into things a little more, Mikunis only made the BST style carbs as small as 29mm. Which could work on the 550 with the correct jetting and probably more. One bike that ran these unicorn carbs was the Suzuki Bandit 250. As for spacing width and lay length, I don't know other than flatslides tend to be shorter length because of the, you guessed it, flat slides they incorporate. So there would be a shortage found between the airbox and the manifolds someplace.
    I'll continue my search for an alternative carb rack set up for the 550.
  8. LarryMc
    Lakewood, WA
    You are closest, I believe.
  9. XJ550H
    could be the flat side carbs mentioned in the clymer repair manual where it tells you how to pod the bike
  10. LarryMc
    Lakewood, WA
    Very true.
    I don't have that manual unfortunately.
    I'll definitely be looking into that for more information...
    Thank you
