Carb rebuild
Discussion in 'XJ Technical Chat' started by Alan92881, Jul 2, 2008.
  1. Alan92881
    Alan92881 New Member
    San Diego, CA
    What is a Pilot screw Blind plug?
  2. chacal
    Also called an anti-tamper cap, it's pressed into the idle mixture screw bore hole after the screw is fitted. It seals the hole against the elements and also makes it very difficult to get at to the idle mixture screw in the future, as it has to be drilled out to remove. I do not recommend installing it!
  3. Alan92881
    San Diego, CA
    very well. I'll leave it out.
    Thanks Wizard
  4. unaverageman
    unaverageman Member
    Twin Cities, MN
    Very good to know as I will be rebuilding my carbs as soon as I get my kits. Thanks for the info.
  5. one2dmax
    one2dmax Member
    It actually works well if you can get some plastic cap plugs and put them in place of the stock ones. Keeps it clean and helps prevent frozen mixture screws.
    Sean
  6. mlew
    mlew Well-Known Member
    Apex, NC
    Plastic plugs work very well. I put some grease in the hole before I put the plugs in , this prevents water from getting in the screws and freezing them up. You can get the plugs at any hardware store.
  7. PaulT
    PaulT Member
    Wilton, NH
    I'd suggest some type of plug after having one of my screws back out on it's own.
    Luckily, a coworker found it, but the spring was long gone.
    At the moment, mine are capped with modeling clay
