Carb seals
Discussion in 'XJ Technical Chat' started by Mustang, Jun 18, 2016.
  1. Mustang
    Mustang Member
    Masonville
    Are carb fuel rIl seals flat or round I replaced everything but thoes
    chacal sells the correct fuel rail seals, eliminates the guess work.
    www.xj4ever.com email address on site or start a conversation with him here.
  3. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    They are O-Rings. They flatten with age.
  4. chacal
    Nope, they are "V"-seals and they shrink with age.......
  5. Mustang
    Mustang Member
    Masonville
    So is an o ring ok to use, bought some at the hardware store
  6. k-moe
    Not really.
  7. Mustang
    Mustang Member
    Masonville
    And she's alive!
  8. wink1018
    Muncy, Pennsylvania
    Did they change the seal type after a certain year? When I first worked on my 81, the carbs had O-Rings on the fuel joints. And I was the first person to get into the carbs on this bike.
  9. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    on my xj600 ,its the throttle shafts that are V shaped , "fuel rails "as op asked were o ring.
    stu
  10. chacal
    Ooops, my bad, that oldenheimer's is kickin' in again...........I thought we were discussing throttle shaft seals.......everyone one else but me is absolutely correct, o-rings are used on the fuel supply pipes and inlet t-fitting (on some carbs; most Mikuni models did not use o-rings on the fuel inlet t-fitting).
    Jetfixer likes this.
  11. Mustang
    Mustang Member
    Masonville
    Your fired lol
